Toshiba Satellite P200D-12C, model No PSPBQE-027009PT laptop/notebook with original OS Windows 7, there is a message: “Toshiba Power Saver”, A fatal error has occurred, this program will be terminated. Code 0x7E
SOURCE: toshiba power saver fatal error code 0x57
try to reinstall your operating system..or restore the system..go to control panel and click the back up or restore files so that all the errors in your computer will fixed..even a fatal error..hopefully this will help your problem..
SOURCE: Power saver error 0x5
Download the hotkey utility from the toshiba web site. I got this errorafter installing service pack 2
for xp. The hotkey utility fixed it.error appeared every time I started
windows xp. Go
to:http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
and go to downloads, select model and download:
Toshiba Hotkey Utility
Install and restart, problem solved. thank you, thank you...
SOURCE: Toshiba Power Saver
It sounds like the built in powersaver utility is crashing. Assuming you can log into the OS after the error, go to Control Panel - Power Options and change to some other (or none at all) setting. And/or uninstall the application completely.
If you can not even get into windows you could try changing the power settings within to bios to disable power saving at all, and that might allow you to boot properly and then turn off/uninstall as described above.
SOURCE: toshiba satellite m40 booting problem.
Hi! It appears that possibly your hrad drive isn't set properly in the caddy? with the laptop powered down and disconnected locate the hard drive cover pop out the two locating screws and carefully move the caddy/hard drive BEWARE as the drive has fragile pins at the opposite end where you opened, hopefully little sliding pressure should remove. Check the retaining screws around the caddy (You'll need a small torx/philips screw driver for this) if all tight replace gently.
If you are uncertain I would recommend a technician check it for you.
Good Luck!
Paul 'W'
Onyer~EDson(:0)~[><
I can log into the OS after the error and all
applications run well. Going to Control Panel - Power Options and trying to
uninstall the application completely to reinstall afterwards, despite the power
saver is in the list, it is not permitted to uninstall and I get an information
that the Power Saver is not in the system anymore, so it seems that the built
in power saver utility crashed. Perhaps there is some malware, but I get the
original Norton Internet Security
installed on the laptop and it is "telling me" that is everything safe.
I already tried to get an updated version of the
Power Saver utility at Toshiba site, but I cannot find the model P200D 12C
anymore.
Could someone be so kind in taking some of their
precious time to give me some additional help, so I would prefer to get a SW
solution, before to go to someone into HW as suggested by Paul W?
Thanks a lot
Jose Matos
Doesn't work, because Power Saver is not in the system anymore, so it seems that the built in power saver utility crashed.
