Thought it may have been transistors on the PCB but they have now been replaced. Motor gives small intermmitant attempts at going
Call Treadmill Doctor and they will also walk you through it Free of Charge. 800-750-4766
http://www.youtube.com/watch?v=4yu7_gAOJD4&feature=g-user-u
SOURCE: Athlon iQ2 treadmill-just replaced motor control
If this is the same problem you had prior to replacing the MCB and speed sensor. I would check the drive motor, unplug unit then remove motor shroud then unplug the connectors leading to the motor itself. If you have wire leads and a 18v drill battery connect the leads into motor then attach the other end to you battery and if the motor will rotate ( approx. 1mph) , if it does the check speed sensor to see if the correct spacing between sensor and front roller ( check if the magnet has not fallen out of front roller pulley this also can cause you problems) hope this help!!
SOURCE: i have a error reading of l5 or ls not too sure york fitness z16
The L5 message means that there is a problem with the speed setting switches. Some models have one set of speed adjusting stitches on the handlebar and another set on the console. One of them is defective and is causing the problem.
SOURCE: the treadmill starts then after a few seconds it
More likely LS= Loss Signal open the motor shroud on the motor their should be a cylindrical shape sensor (magnetic). Plug in treadmill and on the motor control board their should be a L E D (red or amber) by manually rotating the motor you should see that light flicker if it does sensor is good if not replace sensor. Next thing if sensor is good check motor brushes to see if they are mis-align or worn if worn less than 3/8" in length replace them
SOURCE: I have a York z16
LS or L5 error is the speed sensor. Because it is such a vague code I can't just tell you exactly what's wrong with it. I can tell you what it may be.
If you are lucky it's just a fuse. If you have belt movement, it's likely that its just a fuse. If there is no belt movement, it can be a computer failure. the MCB will need replacing.
If you have belt movement and you check the fuse, and its not blown, then the speed sensor is no good and needs replacement.
In most cases its a fuse.
Good luck, hope this helps!
