Goodman CKL42AR42 Air Conditioner Logo
A
Anonymous Posted on Jul 04, 2012
Need goodman outside unit only to replace model cpke30-18
Outside unit bad,air handler is fine. what unit will replace that model and match air handler.
5 Related Answers
Anonymous
  • 3361 Answers
  • Posted on Apr 28, 2009
SOURCE: Goodman SSX16 split system not working
Defective thermostat wire.
Defective contactor.
With the t-stat set for cool and turned down on a low temperature, check for 24 volts at the contactor low voltage hookup. If you have 24 volts, replace the contactor.
You can manually close the contactor to make sure the high voltage is going through it.
Ken Bledsoe
  • 306 Answers
  • Posted on May 02, 2009
SOURCE: Goodman air conditioner will not turn on outside
When ever you hear a buzzing like you are hearing means one thing one of the fuses on the outside disconnect box is bad. Only getting 1/2 the power. Find the bad fuse and get the same size and will be good to go. ken
Robotinner
  • 66 Answers
  • Posted on Jun 30, 2009
SOURCE: five year old goodman unit compressor gone bad.
Depends on if your going to stay with the old refrigerent system of R 22 ro upgrade to the new R410A system. I have been upgreading my customers to 410A if the compressor has failed. Replacement of all components recomended on a compressor burn out.
Greg. B
Sunsetmechanical
Anonymous
  • 340 Answers
  • Posted on Jul 03, 2009
SOURCE: I have a Goodman air conditioner. My outside unit
If you are sure of the power then ya have a control problem thermostat set correctly? could be open low pressure switch I would call for service. Tom
co7196
Ned C Cook
  • 3433 Answers
  • Posted on Jul 29, 2009
SOURCE: Goodman Air (outside unit)
was there any refrigerant loss? "bumping" that results in movng usualy causes a leak.If the system is totally empty, It shouldn't start.. If it did major oh nos! will appear. Does it not start all? and was it running when it got thumped? May have to call a tech out on it. Sorry.
There's goodman air handler in attic space, think it is CK36-1A ,of purchased home. i need a filter size, someone just put in green cut out media.
thats your condenser[outside] unit not air [evap] handler measure it or get model number https://www.searspartsdirect.com/model/cz8f4jp8l3-001755/goodman-ck36-1a-air-conditioner-parts?sid=sem:ggl:DSA+-+Category+-+All+Devices+-+tROAS:76278088766::c&keyword=&gclid=EAIaIQobChMIl5Du35KP-AIVBf_jBx04qwLpEAAYAyAAEgL6s_D_BwE
2answers
Will goodman outdoor ac work with bryant indoor unit
This is true as long as it is not a heat pump. Make sure they replace the piston (metering device to match the outdoor units required piston size. Or if the indoor coil is metered via TXV, it will automatically meter the refrigerant flow. If you are mismatching a system, make sure an acid test is performed on the old refrigerant and take appropriate measures with the new system if the test shows positive acid. They need to definitely install a liquid line drier.
There is no schematic or number on air handler .outside unit is Goodman # CPE48-1FB.How can i get a schematic for Air handler.
I need more info than just the outdoor unit number. The air handler will be a specific number. If you pull the access panel off the heater, there will be a faceplate inside with the unit name and model number as well as a schematic on the back side of the door.
All the wires on the outside of my goodman airhandler
The wires on a Goodman Air Handler Red to R, blue or brown to c, yellow to y cool, green fan g, white to w heat
Goodman a/c unit outside not coming on. buzzing
Sounds like compressor is bad...taken out by a bad contactor.
CONNECT AC TO AIR HANDLER
Wire tstat normaly> Take the Y off the tstat and it goes to the outside unit. The other wire from the outside init goes to the common off the transformer. This is marked with blue,brown or black. Russ
2helpful
I have a Goodman A/C unit. When I turn on the therostat the outside fan does not turn though there is a mild buzz sound. The blower blows warm air inside of my house. What could the problem be?
Does the cpompressor come on if not the sound you here maybe the contactor. Check float switch inside. It is underneath the unit or in front of the air handler. Drain stopped up need to blow out drain. Check outside breakers. possible bad capacitor on unit. Need service tech. Rusty
Need line set size for goodman ck-36-1a
If your running gas heat it's 5/8 3/8 tubing.If it's elec. heat it's 3/4 3/8 tubing. Etheirway 3/4 3/8 works for both. Use 6 wire for tstat from tstat to furnace or air handler, and you need is 2 wire from condensing unit [outside] to furnace or air handler or anything more than two.
Top Goodman Heating & Cooling Experts
Paul Carew
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
