What happens on your cell? Does it shows as charging even if you have removed the charger? Or does it shows as charging when you connect any other cable? If it does It may be the problem of the pin. If not then it the IC problem.
You can check ur email from ur GPRS enabled L7 first u should get the settings from the service provider and then u should save it then u can browse in ur phone.....
Use your main board, swap another phone step by step find down problem.could be keypad or display faulty or cable conector,but my expet display faulty.
Hello, your firmware became corrupt. You need to go to a service center and have the device flashed. It should take only 15 min to flash and should be covered under warranty by the provider or manufacture. If you have no service center near by or its not covered under warranty for whatever reason, check my profile and im sure we can help you.
