Sony wega kp51 turns on for 3 secs than off w/ blinking red light
Sony wega model no KP-FW51M31 projection TV turns on for 3 seconds you hear the sound with no picture than turns off with a blinking red light. When tv was ok a green light is on continuosly
Occasionally, the tv goes beyond 3 seconds and the picture comes on. When this happens the tv stays on is ok although the red light still blinks and not a steady green light but this does not bother me
You can't post conmments that contain an email address.
Re: sony wega kp51 turns on for 3 secs than off w/...
The flashes are fault codes. It means your system is faulty. If it is intermittent then it is more than likely a dust issue. Buy an air duster, spray out the back and restart. Should be fine
If it continues to play up then it will be a repair job
Hi, Question shows tv is Sony KDF-60WF655. Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen. Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure. Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem. Did you replaced its lamp in last 2-3 years? Thanks.
Hi, If you see standby red light blinking on Tv front with 3 seconds interval then count its blinks from pause to pause and let me know, its an error code. And if TV does not even show standby light then check fuse in power supply that would be blew off for some reason, replace it. Still problem? let me know with exact model number of your Sony TV. Thanks.
8 blink error code is usually indicating that the HV transformer ( Flyback) is faulty on the D board. You can get a replacement flyback at the following link with free tech support to explain how to replace it. Heres a link to the correct Flyback for the KP51-65WS500 model sonys. http://servicemanuals.vstore.ca/product_info.php/pName/sony-flyback-145328541/cName/flybacks
