Question about Generac Electrical Supplies
Generac xl 4000 will not keep running after starting
Generac 4000 XL portable generator will start and run for about 10 to 12 seconds and then shut down. Oil is good, cleaned carb and air filter, cleaned out tank and replaced gas filter. It will start on 2nd or third pull after waiting about 10 seconds. I noticed oil shut down switch light will blink when it is almost shut down completely but not but not at normal idle speed.
    Top Expert:
  • Generac Master
  • 33,341 Answers
Try disconnecting the wire going to the low oil switch. if it runs then you need a new switch.
Posted on Sep 02, 2017
2 Suggested Answers
6ya staff
SOURCE:
guarionex
SOURCE: Generac generator will start, run for a moment and
Its the Oil sensor just pack the oil sensor wires together with a smal screw and bolt and try starting if it starts your problem is the oil sensor they tend to go bad I have run through several myself . To avoid hassles I now have overidden the sensor but I check the oil level everytime I need to use the generator
Posted on Sep 03, 2010
I need a rectifier or avr for generac 3500 xl genarator
Ebay and various places including the maker..
  • VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR-GENERATORS ... www.ebay.com/sch/sis.html?_nkw=VOLTAGE-REGULATOR-3000-3500-WATT... VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR ... New listing 3500 Watt Generator AVR Automatic ... 3500W Generator AVR Automatic Voltage Rectifier ...
  • 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator ... https://sites.google.com/site/kltthtyz0i04cd/3500-w-3500-watt... Generac Guardian 22kW Standby Generator NG ... Previously Pay for Shop 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator Rectifier 3.5KW Generator AVR ...
  • How to test your Electricity Generator's AVR, Brushes and ... www.youtube.com/watch?v=tC_LrrZcx38
    • BY GENERATOR GURU
    • 9 MIN
    • 454K VIEWS
    2011-10-21 · Video embedded · When your electricity Generator stops producing power, ... How to test your Electricity Generator's AVR, ... Generac iQ: The Quietest Generator ...
  • Generac Power Systems - Home www.generac.com Generac manufactures the widest range of power products in the marketplace including portable, RV, residential, commercial and industrial generators.
  • Generac Guardian Generator Voltage Regulator Rectifier ... www.ebay.com/sch/sis.html?_nkw=Generac+Guardian+Generator+Voltage... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator ...
  • Automatic Voltage Regulator (AVR) for Generators portable.generatorguide.net/avr.html How automatic voltage regulator (AVR) works in portable generators: ... here you can see a reverse engineered Generac regulator that uses SCRs and UJT.
  • Diagnosing A Generator That Has No Power Output. - YouTube Youtube
    • BY THEDIYGUYDOTNET
    • 3 MIN
    • 150K VIEWS
    2012-11-12 · Video embedded · Diagnosing A Generator That Has No Power Output. ... How to test your Electricity Generator's AVR, ... Generac Portable Generator ...
  • GENERATOR Diagram & Parts List for Model 3500xl Generac ... www.searspartsdirect.com > ... > 3500XL GENERAC Generator-Parts GENERATOR Diagram and Parts List for GENERAC Generator-Parts model # 3500XL ... Generator rectifier Part #: ... Generator voltage regulator Part #: ...
  • Jun 28, 2016 | Generac Electrical Supplies
    What kind of oil do you use
    Judy, Generac portable generator oil recommendations. Above 40°F, use SAE 30. Below 40°F and down to 10°F, use 10W-30. Below 10°F, use synthetic 5W-30. Oil should be changed after the first 8 hours of operation and every 200 hours of run time thereafter.
    Check the attached links,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    http://www.generac.com/service-support/faqs/portable-generator-faqs
    http://www.generac.com/service-support/faqs/home-backup-faqs
    Best oil for Generac generator Lawn Mower and Small Engine Bob Is The Oil...
    Generac Generator Oil Change
    Apr 18, 2016 | Generac Electrical Supplies
    Generator hard to start and sputters like its missing
    About 15,000 results (0.73 seconds) Search Results
      2 - Generac : Questions, Answers, How To, FAQs, Tips ...
      answers.generac.com/answers/1506-en_us/searchquestions.htm?...
      Can I run an 8kw standby generator on a 100 lb propane tank? 2 answers ... What am I getting for the extra cost of the Guardian unit? ... The engine starts hard and runs rough. 1. Air ... On auto start, unit sputters and I smell gas. ... Does the gas and electrical feed into the unit from the back as previous air cooled units?
      2 - Generac Questions and Answers
      answers.generac.com/answers/1506.../generac.../questions.htm?...
      On auto start, unit sputters and I smell gas. .... The 20kW automatic standby generator has the option to delay start up during an ... This is for a guardian 20kw. ....has been designed to make the battery installation and removal so difficult? ... The air cooled generators are designed to allow for the smallest footprint while still ...
      3 - Generac Questions and Answers
      Generac's Guardian Series 17kw automatic standby generator does not come with a.... The automatic response features of our air-cooled units initiates the unit's startup,.... This week I tried the same and it tries to start but just sputters and fails until .... A C delayed start still chocks 17kw generator would a hard start kit help?
      On auto start, unit sputters and I smell gas. On manual start ...
    Feb 08, 2016 | Generac Guardian Air-Cooled Standby...
    Starts up but will not run but for a few seconds
    Check the oil. Some engines will shut down if the oil is low. Otherwise you probably have a dirty fuel filter and the carburetor fills up with gas long enough to start but isn't getting enough gas to keep it full.
    Feb 13, 2014 | Generac Guardian Ultra Source 15,000 Watt...
    Cranks then dies
    yes this unit will run for only a second or two then dies. the fuel pump is pumping well
    Apr 24, 2012 | Generac Power Systems Generac 5734 15000...
    Need Users manual for Generac 4000 EXL generator
    Hi and welcome to FixYa, I am Kelly
    Below is a list of all the manuals an owner should have:
    For the 4000 EXL Your actual model number is 01645.
    Operators manual:
    http://www.generac-portables.com/document/index.cfm?doc=1645_0EN11CS_LO.pdf
    Wiring Diagram:
    http://www.generac-portables.com/document/index.cfm?doc=1645_0WDS_LO.pdf
    Parts List:
    http://www.generac-portables.com/document/index.cfm?doc=1645_0PARTSLISTCCS_LO.pdf
    Thanks for choosing FixYa,
    Kelly
    May 18, 2011 | Garden
    Generac NP 50G Stops after 2-30min.
    check the oil sensor circuit. I know when I take out or short out the sensor ckt on mine, it'll keep on running. low oil isn't good for any motor.
    Oct 20, 2009 | Generac Guardian Ultra Source 15,000 Watt...
    Electrical Supplies Logo
    138 people viewed this question
    Top Generac Electrical Supplies Experts
    Sheldon Dedek
    Bob Janelli
    Level 1 Expert
    JOHN LAPIER
    Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
