Question about Pride Celebrity X 4-Wheel Electric Scooter
Code blinks 5 pause 5
Scooter stopped, i turned key off then on many times it won't go. code lite blinks 5--5 over and over
    Novelist:
  • 60 Answers
Either your parking brake is engaged or if your scooter is more like mine i have a Rascal 600t it gives a code 5 service code when it thinks its in free wheel. The freewheel mechanism is located on the trans-axle which if you go outside across grass it gets wet. Th is device doesn't like moister and will get stiff will partially engage or disengage. In that mechanism there is a micro-switch which if the lever when slipped into the engaged position doesn't go all the way to the seated position the switch will see the mechanism as being disengaged [in free wheel] and will inhibit the motor from running. I lubricate the entire assembly with pure silicon spray oil,WARNING, do not use WD-40, It will eat some plastics.After lubricating the lever should move smoothly. I have to lub my scooter about once a month in the winter.
Now if this doesn't work check the connector that are all the wires are connected. Disconnect the connector check the pins are ok reconnect check to see if your still getting the failure. If you are still getting this problem do continuity checks on the wiring. You will need a multimeter only $9
http://www.amazon.com/Mastech-YG188-Pocket-size-analog-multimeter/dp/B00064CH6A/ref=sr_1_8?s=hi&ie=UTF8&qid=1339024102&sr=1-8 Check the switch in the freewheel assembly. Select ohms the highest scale, short the leads together, zero the meter by turning the zero adjust knob. There is only one wire we are interested in. On some scooters you can visually see the switch and the wire running from it. The wire usually foes to a spade connector. Disconnect the spade connector put a probe on that connector leading to the switch. Disconnect the battery put other probe on the positive side of the terminals that were connected to the battery not to the battery it side.Work the switch does the meter needle deflect to zero, no, try the negative side. Does the meter deflect, no, put the probes directly on the switch terminals, does the switch.when worked now cause the meter to deflect, no, replace switch, yes, the problem is in the harness, don't panic, use can use that meter to trace the wire through the harness. Wiggling wires and flexing connectors usually makes the meter flick at some point. Thats how i do it i'm never without my trusty meter. Rascal are notorious for having problems of this type my mid-frame harness fell apart in the middle of a six lane intersection, the scooter simply locks up tight .I can do nothing but sit in the middle of this huge intersection. People try to move me but the scooters wheels are locked, my illness makes it so i can't communicate with people do it was a mess. So i modified the connector so its no longer a latch type connector. I drilled it for a quick pin which is much stronger than what its using now. Hope this helps
Posted on Jul 07, 2012
SOURCE:
My scooter wont go all of a sudden and the red light on the console is blinking a sequence of 4 times
Amigo Scooter Oxygen Tank Holder Light flash key turned ...
www.fixya.com > ... > Amigo > Amigo Scooter Oxygen Tank Holder
... key on my phoenix 3 scooter the red light flashes 5 times and the scooter will ...scooter wont move,although on the little speedo there is a red light flashing on ... ...light is flashing when the key is turned on. the scooter does not move at all ... flash up and down the console light and you at this point have to turn the key off ...
My pharmore wizard diagnostic light flashes 9 times and my ...
www.fixya.com/.../t25197681-pharmore_wizard_diagnostic_light_flashe...
Oct 8, 2014 - my pharmore wizard diagnostic light flashes 9 times and my scooterdoes not go, can someone help me please - Mobility Scooters question. ... Have no manual for pharmore 4 wheeled wizzard light on but wont move ... Why did it stop working suddenly and is blinking console light in 5-blink sequence?
Jan 31, 2016 | Video Game Consoles & Games
The error lite on Buzzaround Lite scooter flashing
5 flash code is the electro magnetic Brake. This is referring to the brake on the motor that can be released by the freewheel lever.
1. place the freewheel lever into the free wheel position. Ensure the scooter is in free wheel and move the scooter forwards and backwards a few times.
2. Place the freewheel lever in drive position, push on scooter to ensure it is in drive and does not move. Turn on key and press the throttle. If you have the same code again, call a technician to check the brake, chances are it needs replaced.
Aug 25, 2014 | Health & Beauty
Repair pride dart mobility scooter when turn on green light blink on won't moved
The blinking light is a fault code. The light will blink a series of blinks and then pause. To better answer your question you will need to know the fault code the scooter is giving
Oct 26, 2013 | Universal D5722alt9-compatible Wheelchair...
Celebrityx scooter blinks 5 pause 5 everytime i turn key on
Either your parking brake is engaged or if your scooter is more like mine i have a Rascal 600t it gives a code 5 service code when it thinks its in free wheel. The freewheel mechanism is located on the trans-axle which if you go outside across grass it gets wet. This device doesn't like moister and will get stiff will partially engage or disengage. In that mechanism there is a micro-switch which if the lever when slipped into the engaged position doesn't go all the way to the seated position the switch will see the mechanism as being disengaged [in free wheel] and will inhibit the motor from running. I lubricate the entire assembly with pure silicon spray oil,WARNING, do not use WD-40, It will eat some plastics.After lubricating the lever should move smoothly. I have to lub my scooter about once a month in the winter.
http://www.amazon.com/Mastech-YG188-Pocket-size-analog-multimeter/dp/B00064CH6A/ref=sr_1_8?s=hi&ie=UTF8&qid=1339024102&sr=1-8 Check the switch in the freewheel assembly. Select ohms the highest scale, short the leads together, zero the meter by turning the zero adjust knob. There is only one wire we are interested in. On some scooters you can visually see the switch and the wire running from it. The wire usually goes to a spade connector. Disconnect the spade connector put a probe on that connector leading to the switch. Disconnect the battery put other probe on the positive side of the terminals that were connected to the battery not to the battery it side.Work the switch does the meter needle deflect to zero, no, try the negative side. Does the meter deflect, no, put the probes directly on the switch terminals, does the switch.when worked now cause the meter to deflect, no, replace switch, yes, the problem is in the harness, don't panic, use can use that meter to trace the wire through the harness. Wiggling wires and flexing connectors usually makes the meter flick at some point. Thats how i do it i'm never without my trusty meter. My scooter a Rascal are notorious for having problems of this type my mid-frame harness fell apart in the middle of a six lane intersection, the scooter simply locks up tight .I can do nothing but sit in the middle of this huge intersection. People try to move me but the scooters wheels are locked, my illness makes it so i can't communicate with people, it was a mess. So i modified the connector so its no longer a latch type connector. I drilled it for a quick pin which is much stronger than what its using now. Hope this helps
Jul 05, 2012 | Pride Celebrity X 4-Wheel Electric Scooter...
My car wont stay idling
Lets start with figuring out why the check engine light is on. You can get a blinkout of the the code by switching you key to the on and off position three times quickly and leaving it in the on position on the final time (note, do not take the key so far that it tries to start the engine). So start with the key in, and engine off, quickly turn the key to on, then off, then on, then off, then on and leave it there. Now watch your check engine light. It will blink out any codes that may be stored. The blinking will have breaks between each code and each code is a two digit number. For instance, blink short pause, blink blink, long pause, blink, blink, blink, pause, blink, blink, would be codes 12 and 32. I believe the final code is 55 and just simply means "end of codes". That should at least tell you if its an issue the ECU has detected. You can do a quick google search to find out what each code it spits out means. As for a guess as to why it isn't idling...I've seen everything from a failing fuel pump (inadequate pressure), to a clogged EGR valve cause this. Could be quite a few things unfortunately. Good luck!
Feb 25, 2012 | 1995 Chrysler LeBaron
Power eye blinks when turned on,but scooter will not move. Back brake lever is bent, but has been operating until this a.m. Back brake not releasing properly.
Count the number of times the power light blinks between pauses ie 4 blinks pause 4 blinks etc and this is the fault code If you have the users manual it might tell you what the code means. As long as the power eye blinks the scooter will not move and without knowing the error code I can't give you the definite answer Good luck
May 17, 2011 | Electric Mobility 24 " Seat Merits Heavy...
Golden companion II full charge turn key on press lever to go forward it dont move hear clicking sound green light on dash blinks
John count the number of flashes by the green light and it will be the fault code indicating the problem Your owners manual should list the fault codes to be able to determine what the problem is. Ie 4 blinks pause 4 blinks pause. The clicking you hear is the electric brakes being engaged. Hope this helps
Mar 01, 2011 | Golden Technologies Companion II Travel...
When turning on joystick control the chair moves but when i stop the lights start to blink and stops moving horn works if i play with the on/off it start to works agian
fantasy when it stops count the number of flashes. For example it might flash 5 times pause flash 5 times pause etc. This is the flash code and your manual will give you what it means. Being an intermittent problem can be a bear to trouble shoot. It would be nice to know what chair you have and whether Medicare purchased the chair for you. If Medicare purchased the chair then they will pay for most of the repair cost Hope this helps you
Sep 10, 2010 | Health & Beauty
Pride Celebrity X 4-Wheel Electric Scooter  Logo
185 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
