Condensate pumps dont work with the thermostat . The pump has an internal float switch that kicks the pump on when the water reach a high level. If the pump failed for any reason the safety swicht will turn off the ac unit to prevent any water overflow.
The power is regulated by an internal sensor inside the car, this should be close to the vents, you need to check the compressor first, because that is the main regulator if you bypass the regulaors and power it directly you will not find the problems.
SRS (airbag) light needs to be reset by dealer or a really good specialty shop. It's a safety issue. Keep in mind if light comes back on you DO have a problem with your SRS and it needs to be addressed.
It depends if your fridge has a electronic control board on it.It can damage during a power failer.Cheak on your hydro distributer for help they may pay for your repair:) Hope i helped
The
SWICHT is one but you must be sure that is the bad SWICHT that could be
the motor of the window you have to check this by measuring the voltage
at the terminal entering the engine
try jumping the starter in neutral or park with the key in the on position. if it doesnt work replace the starter. also check your ground cable going from the battery to the engine block, if it's loose or frayed replace it
