SOURCE: don't know the universal remote code.
hi! i have here a couple of codes for your tv! just try them, 1004, 1007, 1018, 1027, 1047, 1056, 1057, 1059, 1060, 1061, 1103, 1124, 1145, 1150, 1153, 1279, 1296, 1387, 1464, 1483,1046, 1465,
1150, 2092, 1464, 2408, 1465, 2260, 1027, 2064, 3105, 1124, 2078, 3088, 1296, 2213, 3147, 1145, 3095, hope this helps!!!! goodluck!!!!
SOURCE: WHAT IS DIRECT TV CODE FOR SYLVANIA LC370SS9
hi! i have here a couple of codes for your tv! just try them 1004, 1007, 1018, 1027, 1047, 1056, 1057, 1059, 1060, 1061, 1103, 1124, 1145, 1150, 1153, 1279, 1296, 1387, 1464, 1483,1046, 1465,1150, 2092, 1464, 2408, 1465, 2260, 1027, 2064, 3105, 1124, 2078, 3088, 1296, 2213, 3147, 1145, 3095, hope this helps!!! goodluck!!!
SOURCE: How do you Wall mount
If you have a wall mount kit, it is fairly simple. You just find the place that you want the tv to go and find a nearby stud to install the mount. After that you will want a second person to help with either holding the tv up or screwing in the tv to the mount. There are four screw holes in the back of the tv to screw through the wall mount plate into the back of the tv. Check to make sure it is stable, then you have successfully installed the tv to your wall
