I forgot my Nokia E72 Phone's LOck Code. When I turn ON my Phone It always ask for my security code and I forgot my security code pls. Help me! My IMEI = 351513048483520 My e-mail Add: [email protected]
Hi it is not a hard task..just follow this link for instruction How to Generate Your Phone Security code..Only for Nokia bb5.you can easily generate your current code.But first you need to do is to collect E72 compitable USB cable.After you get the code you can Restore your phone by using the generated codes.Good luck
SOURCE: nokia N80 "phone lock code"
Hi have you tried 0000 thats usually the code that is stored when phone is new failing that you will need to get a flash lead and nokia softtware that scans the phone and gives you all the codes allowing you to change them but this is expensive to buy.
I have alot of nokia software but not sure if it works through usb lead as i use from computer then into black box then into phone as i have this as it works on all makes an model of phone if it can be done through the usb lead i can tell you where you can get this software from ok just give us a shout back
SOURCE: nokia 3110c mobile, i forgot security code.now how to reset security code?
plz downlod new softwear
SOURCE: i forgot my security code and now i want to
Master reset code: 0415531240
Rate this solution.
SOURCE: orgot my security code Nokia 1100
Your IMEI: 359399009958078
Your Nokia Master Code: 6260611472
Steps to type Master Code:
1.This is master code.It has to be entered when your phone is started and asks for code..(security or master)..
2.If you type 5 times wrongly,the phone will get whole locked.. so,try 1 time.
3.If you fully typed 5 times wrongly ,you have to get a software tool to unlock and that costs greater than the phone you got..
so,try 1 time and let me know..
my email id:[email protected]
