Need to clean mildew from louvers and inside
SOURCE: Drain Hole for Frigidaire Window Air Conditioner
Leave it alone. DO NOT attempt to create a drain. As long as a window A/C unit is installed properly, (angled slightly down toward the rear) it will drain excess water over the rear lower lip of the unit should it get that high. Many models use some of the collected water/condensation. It gets lifted up by the fan blades to cool the coil.
SOURCE: The interior of the air conditioner behind the
Remove the front of he unit, as if you're going to clean the filter. That will give you access to what you need to clean. Use warm water and dish washing liquid to wipe off the mildew. Rinse with clear water and a sponge, dry thoroughly and replace the filter and the front of the unit.
NOTE: Before attempting any of the above. Turn the unit OFF & Unplug it.
