Casio ILLUMINATOR DUAL TIME MEN WATCH Watch for Men Logo
Posted on Jul 04, 2012
What is dual time for? - Casio ILLUMINATOR DUAL TIME MEN WATCH Watch for Men
I need a user manual for a SHARK Dual Time Silicone Band Digital White Watch SH041
It is an AliExpress special made in China. You can get the manual for $245 and you get a free watch :>D
Scribd says it has a manual
https://www.google.com/search?q=SHARK+Dual+Time+Watch+SH041+manual
May 03, 2023 • Watches
1helpful
How to make my Casio watch band smaller ?
To adjust the dual time on your Tommy Hilfiger watch model 1791709, follow these steps:
  1. Press the "Mode" button to enter the dual time mode. The dual time mode is indicated by the small "D" at the top of the display.
  2. Hold down the "Adjust" button for a few seconds until the hours digit starts flashing.
  3. Press the "Adjust" button repeatedly to adjust the hours of the second time zone.
  4. Press the "Mode" button to move to the minutes digit, which will start flashing.
  5. Press the "Adjust" button repeatedly to adjust the minutes of the second time zone.
Does anyone know how to adjust dual time. Cant seem to adjust the second time..Tommy Hilfiger 1791709
To adjust the dual time on a Tommy Hilfiger 1791709 watch, you will need to follow these steps:
  1. Locate the crown (knob) on the side of the watch.
  2. Pull the crown out to the second position. You should feel a slight resistance as you do this.
  3. Turn the crown clockwise or counterclockwise to adjust the time on the second time zone. The time on the main display will not change.
  4. When you have set the correct time, push the crown back in to the original position.
It is important to refer to the user manual for your specific watch model for detailed instructions on how to adjust the dual time feature. If you are unable to adjust the dual time on your watch, it is recommended to have it serviced by a professional watch repair technician.
Wala
As the question is incomplete, there are suggestions: 1. Dual watch is reversible watch where the watch face is on both sides. Each face usually have different design and features. Wearer is wearing two watches at once and can choose which one can be visible. 2. Dual watch can be dual time watch. That means watch has capability of showing time in two different time zones at once.
Manuel for yacht timer 700 please. Best regards P.Hessner
Could not find a download for instructions on this watch, but I did manage to find some basic instructions for the Sector brand. I hope this helps as this is the best I can come up with.
Good luck.
Sector Chronograph Watch Instructions
  • Most chronograph watches have screw-down crowns for water resistance. You must unscrew the watch crown before you can make any changes to the watch time. After time is set screw the crown back in. To utilize the chronograph dials, use the buttons on the side of the watch. One button will be for the second timer. Press once for the second hand to start timing. Press again to stop it. Another button will be to reset the second hand timer back to zero. Sector Chronograph watches may have different dial functions (see link in References).
  • Sector Dual-Time Watch Instructions
  • Because Sector watches are known for their sports capabilities, the Dual-Time watches have screw-down crowns. For Dual-Time timepieces, unscrew the crown counterclockwise. Pull the crown to middle position to set the date. Pull the crown out to its fully extended position and rotate it to set the day of the week, hour and time. Press and hold in the crown and turn clockwise to seal the crown back in to the watch.
  • Sector Ana-Digi Watch Instructions
  • Sector Ana-Digi timepieces have analog hands plus digital timekeeping functionality. To set the time, unscrew the crown counterclockwise and then clockwise to the appropriate time. The digital functionalities are programmed by the buttons on the side of the case. Depending on the style of the Sector watch, you can set the digital time with one button, set the date display, 1/100 seconds chronograph timer, altimeter, thermometer and alarm functions.
  • 3helpful
    Unable to set the dual time on my new watch
    Click on my profile (escapement), then click on Tips and Tricks. There you will find link to B&M watch manuals.Rate me, please
    1helpful
    2answers
    How do i take my george watch out of 24 hour time?
    how do you set the time on the digital george watches?
    Nov 21, 2009 • Watches
    Red hand for dual timezone
    If your watch has mechanical- self winding movement, then ALL the gears, hands and functions are mechanically driven and executed. None of the hands can be winded, as the movement of the hands is the consequence of the releasing power of the winded mainspring. All hands (including dual time zone hand) can be udjusted only to the required time and the rest is done automatically by the gears, cogs and levers.
    If the dual time zone hand is not functioning properly- there is some mechanical fault and you will have to get the watchmakers help to sort it out.
    Do not forget to rate, please.
    Rado diastar swiss 196-0364-3
    I bought the same watch recently and have the same problem. The hours can be adjusted in the dual time zone by looking up the manual, but the minutes stay put. I can't bring them to blink so that these could be adjusted. Any ideas? I sent a mail to Rado through their website but no answer.
    10 year old alarm chronograph
    good morning ! your anadigi chronograph 388 is veery easy to operate,just change the battery then short the reset button the fix the case back and set the time use the crown and the button to set the time calendar and the alarm !thank you ! god bless !....
    Top Casio Watches Experts
    k24674
    Robert
    ZJ Limited
    ZJ Limited
    Are you a Casio Watch Expert? Answer questions, earn points and help others
