Question about Northgate (STAX2517C2) PC Desktop
Cmos checksum error - Northgate (STAX2517C2) PC Desktop
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
Sounds like the battery is dead in the computer itself, its a watch battery you will need to reset the clock and some other settings in the bios
Posted on Jul 04, 2012
SOURCE:
A 1xx POST error code indicates a problem with the ??
It indicates a problem with the system boards. For more info, start here.
Oct 30, 2012 | HP Computers & Internet
Getting a CMOS checksum bad error when starting my Acer M5640 Desktop with Windows 7 Thanks Daniel
Solutions to CMOS Checksum Bad Error
The CMOS Checksum Bad Error can be fixed easily by following the listed steps carefully.
CMOS Battery may not be functioning properly
If you suspect that your CMOS battery is not functioning properly, you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all the settings are lost, you can usually retrieve them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computer's manual or technical support to remove your battery (the battery a flat, shiny silver colored and coin-shaped). Take down the CMOS battery's information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have solved the problem.
Your BIOS may have been updated
If your BIOS have been updated recently, your CMOS settings may have reset. Make sure that the values entered in the BIOS are correct or simply reset them to the default settings. If you believe that a virus has updated your BIOS settings, run a virus scan and make sure that the BIOS settings are back to the default.
The Computer may not have been shut down properly
Sometimes when running MS Windows, if you shut down your computer without first properly shutting down your operating system, it will corrupt the CMOS settings causing the CMOS Checksum Bad Error. You can easily avoid this error by making sure that you completely shut down your computer properly before turning off the main power. Usually this entails going into the Start Menu, clicking on Turn Off Computer/ Shut Down. If improper shutdown was the cause of the error, you may have solved the issue.
akuma_ryu21 rate it pls!!
Jan 21, 2011 | Computers & Internet
Cmos checksum error & keyboard not function
CMOS checksum errors
Explanation: A checksum is computed as an error-detecting code, to protect the BIOS settings stored in the CMOS memory. Each time the system is booted this number is recomputed and checked against the stored value. If they do not match, an error message is generated to tell you that the CMOS memory contents may have been corrupted and therefore some settings may be wrong. BIOSes react in different ways to encountering this sort of error. Some will warn the user and then continue on with whatever settings were in the CMOS. Others will assume that the settings that were in the CMOS were corrupted and will load default values stored in the BIOS chip "for safety reasons". The error message will indicate which your system is doing.
Diagnosis: The most common cause of checksum errors in CMOS is a battery that is losing power. Viruses can also affect CMOS settings, and motherboard problems can also affect the stored values.
Recommendation: Follow the instructions in this section to address the CMOS corruption. You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values (hopefully against a recent BIOS settings backup).
Sep 24, 2010 | Computers & Internet
Came home computer was on black screen and now it won't reboot. When I try to reboot, I get a "cmos checksum error ". Keyboard also isn't working. What could be the problem?
The CMOS checksum error occurs when the CMOS battery is worn out and the CMOS data gets corrupted. Replace the CMOS battery, this battery most likely a CR2032 lithium coin size button battery - check to make sure before you purchase.
After replacing with a new battery, then go to the BIOS configuration and set the Time & Date etc.
Sep 02, 2010 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Booting problem
There are usually three main reasons that a CMOS Checksum Bad Error has occurred. They include:
  • CMOS Battery may not be functioning properly. The battery life may have expired.
  • Your BIOS may have been updated (either by user or possibly a virus)
  • The computer may not have been shut down properly e.g. shutting off the computer's main power without first shutting down the computer (MS Windows requires you to shut down your computer before shutting off the power).
Solutions to CMOS Checksum Bad Error The CMOS Checksum Bad Error can be fixed easily by following the listed steps carefully.
If you suspect that your CMOS battery is not functioning properly, you can easily change it. Before changing your battery, reboot your computer to make sure that the error still exists. If it does, go into your CMOS and write down all of the settings. If all the settings are lost, you can usually retrieve them from your computer manufacturer. Now locate the battery and remove it, you might need to consult your computer’s manual or technical support to remove your battery (the battery a flat, shiny silver colored and coin-shaped). Take down the CMOS battery’s information such as volt, size, etc. Once you have your new battery, you can replace it and reenter your CMOS settings. If your battery was the cause of the CMOS Checksum Bad Error, you should have solved the problem.
Mar 05, 2010 | Microsoft Windows XP Professional With...
Intel 102ggc:The Firmware has detected that Cmos Checksum Error
Hi there.
Basically you first bios update was bad, if you can get into the operating system re-flash the bios again, that will sort it out.
Good luck and thanks for choosing FixYa!!
Jun 02, 2009 | Microsoft Windows XP Professional Upgrade...
CMOS checksum error
Can you leave a better description of the problem?, are you getting 'cmos checksum error' msg when you startup? If so, this is normal after removing the CMOS battery and replacing, it should only display error msg after 1st start then no more...
Dec 30, 2008 | ASUS A8N5X Motherboard
CMOS Error
Are the CMOS batteries good?
Oct 15, 2008 | Biostar P4M80-M4 Motherboard
CMOS checksum error
rahul23petit
"CMOS" checksum error default loaded" means ur mother board cmos battery fail (which is locate at mother board), to solve this problem replace it by new one (u can buy it form any computer accessories shop). all oher problem happen for it.
Jul 06, 2008 | EliteGroup BKi810 Motherboard
Northgate (STAX2517C2) PC Desktop Logo
26 people viewed this question
Top Northgate Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
Håkan Sterner
Carlo Barzo
Carlo Barzo
Are you a Northgate Computer and Internet Expert? Answer questions, earn points and help others
