SOURCE: Drain Hole for Frigidaire Window Air Conditioner
Leave it alone. DO NOT attempt to create a drain. As long as a window A/C unit is installed properly, (angled slightly down toward the rear) it will drain excess water over the rear lower lip of the unit should it get that high. Many models use some of the collected water/condensation. It gets lifted up by the fan blades to cool the coil.
SOURCE: my ac window unit does not seem to have any
SOURCE: water doens't drain properly and sitting there,
that's fairly common for window units, it's ok to drill a small hole in the underside of the case to drain the water, just be sure you don't puncture the condenser in the process.
SOURCE: Can a 12000 BTU thru the wall AC be installed as a
Yes... no problem... just need to use cardbord of something to seal off the open spaces around it...
heatman101
Testimonial: "Thanks for the speedy reply and your time."
SOURCE: I have a Frigidaire FAM18ER2A Window Air
May be rat or squirrel trapped in fan blade. Remove the a/c and water wash and re fix it.
