SOURCE: Waste Toner Full/ Not Install
Behind the little container for the waste toner there is a sensor that senses whether the toner basket is full or not. If the sensor itself is dirty, it can give a false reading. First try cleaning out the area under the container to see if the switch works. Also make sure the container is clean, because the sensor works by sight, so if it looks full because it's dirty, it will give a false reading. I have heard of people disabling that sensor in various ways, but that can get dangerous to the printer. I can't recall the details on that exact model, but I believe there is a diagnostic of some sort that can test that sensor to make sure it works right to begin with.
SOURCE: Waste Toner
Remove the left rear side cover waste bottle is in the left rear corner of machine ..make sure to clean the neck of the bottle really good it uses sensor to know when full, if toner deposits stay on neck of bottle it cant see threw it so still thinks it is full, Toner is messy stuff, empty with care, while you are there locate the sensor that looks threw the neck and clean that too. You just saved 100bucks!!
SOURCE: Replace used toner message still on
You have to clean the small clear tape tab on the side of the bottle. The "eye" sees whether or not the bottle is full.
You can remove it, clean it and replace it. Use caution with it. I've actual made new ones using clear packing tap on top of a small piece of clear plating that I cut out to fit on there.
Good luck. Be sure to rate this if it helps.
SOURCE: replace waste toner container message
I have a CLX-2160N and have just emptied my own waste toner container. (Disclaimer: not sure how toxic or environmentally friendly this is).
Emptied carefully and thoroughly (fine dust). Immersed in bowl of warm soapy water, and vigorous shaking to get nice and clean.
Shook all water out well, and dried off as much as possible. Reinstalled. Turned printer back on. Hey presto - seems happy.
SOURCE: Toner waste container location
The waste toner is in the front, open front cover and the white bottle in the middle is the waste toner cartridge. Remove the black screw, and empty or replace the cartridge.
The life of the waste toner container unit is approximately 1,250 pages
for full color 5% image printing or 5,000 images for black printing. When
the life span of the waste toner container has expired, Replace/Install
Waste Toner Tank appears on the display of the control panel,
indicating the waste toner container needs to be replaced. Otherwise
your printer stops printing.
To replace the waste toner container:
1 Turn the machine off, then wait a few minutes for the machine to
cool.
2 Open the front cover.
3 Pull the waste toner container out of the machine using its handle.
4 Remove the container's cap from the container as shown below,
and use it to close the waste toner container opening.
5 Take a new waste toner container out of its package.
Tip
Make sure that you lay the waste toner container on a flat
surface so that the toner does not spill.
Caution
Do not tilt or turn the tank over.
6 Insert the new container into position and then push it to make sure
that it is firmly seated in place.
7 Close the front cover firmly.
8 Turn the machine on.
Caution
If the front cover is not completely closed, the machine will not
operate.
Tip
After rebooting, your machine will automatically reset the
counter for the waste toner container
From the manual:
http://download.support.xerox.com/pub/docs/6110MFP/userdocs/any-os/en/B_Guide_EN.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
