Question about Homelite Garden
Fuel mix for homelite hht2660 hedge trimmer
The homelite HHT2660 hedge trimmer what is the right fuel mix please
  • Voice Dude
    Voice Dude Jul 10, 2019
    The correct fuel ratio for the Homelite HHT2660 is 33:1
    Loyalty:
    Visited the website for 30 consecutive days.
  • Homelite Expert
  • 348 Answers
What we normally say is good quality two stroke oil 50-1, two stroke oil from unknown manufacturers 25-1
Posted on Jul 10, 2019
SOURCE:
trippssmengi
  • 76 Answers
SOURCE: oil ratio
you can use a 40:1 mix if it smokes then cut it back to 32:1 but a little more oil is better than not enough so start with the 40:1
Posted on Jan 18, 2009
  • 11 Answers
SOURCE: Wont coil back into its housing, so trimmer wont start. Has compression though
Hi, this a cut&paste from elswhere but it applies to your problem:
how to repair a recoil spring: whats missing is this, you should always wgear eye protection when dealing with springs of any kind.
remember safty first. :)
Remove the recoil shroud and take a look at the assembly.
You might have a broken spring or just a rope that has slipped out of the reel.
The spring usually breaks at one of the end tabs. If so, you will need to get a replacement spring and carefully wind that in, before re-assembling the rope reel. You might wish to replace the rope also, if it shows signs
of wear.
You will need to remove the entire cooling shroud. There should be 4 bolts on the sides. You might need to remove the fuel tank also. Pre-wind the recoil reel by hand [about 6 turns, to set the spring tension] and clamp it with Vise-Grip pliers. Remove the old rope. Thread
the new rope through the shroud housing eyelet and to the reel hub. Let the reel re-wind itself until it is full. If there is not enough spring tension you can wind it a couple of turns more by slipping the rope around
between the reel and shroud. Re-clamp the reel. Cut the rope to length and thread it though the handle. At all knots, burn and melt the rope with a
lighter to prevent untying. Re-assemble.
(special thanks to "Micheal"the author)
Posted on May 19, 2009
SOURCE: sharpen hedge trimmer blade??
My trick is to make sure that I always lube the blades after each session with a 3/4 engine oil + 1/4 kerosene mix - making sure that every tooth gets a drops or 2, then run it for a seconds to spread the oil & leave the blades overlapping. Doing this allows the blades to self sharpen I've found. 2 stroke oil , unmixed is about the perfect viscosity aswell.
Posted on Feb 18, 2010
  • 5 Answers
SOURCE: homelite hedge trimmer , motor runs but blades do
Had the same problem: when I turn on the trimmer, the motor would hum but the blades won't move.
What I did:
1. Sprayed a ton of wd40 between the blades
2. Took a screwdriver and kinda wedged it between the blades to get them unstuck. Also removed some guck between the blades.
And it worked!
Posted on Jun 09, 2010
  • 2468 Answers
SOURCE: Fuel Ratio
40:1 gas/oil mixture
Posted on Jun 14, 2010
Fuel Ratio What is the fuel Ratio for the Homelite HT -17 Hedge trimmer?
2 stroke tools generally run at 50:1
100ml of oil in 5L of petrol
Oct 29, 2015 | Homelite Garden
Any special procedures to starting an old ST-175 homelite weed trimmer that has not been run on over 8 years.
the carb and fuel lines will most likely need repair, i would mix a little extra 2 stroke oil in the gas on the first run, and a few drops 2 stroke oil in the cylinder is a good idea..oh and you might want to check the spark arrester on the muffler .. jay
Dec 31, 2011 | Homelite Garden
What is fuel/oil mix ratio for ht22 hedge clipper
50 to 1, 20 ml per liter or 2.6 fluid oz per US gallon
Sep 19, 2011 | Homelite Factory Reconditioned 26cc...
Wat is mix ratio for homelit ht-17 hedge trimmer????
If ever in doubt, always run them on a 25-1 fuel oil mix, this is good for any small two stroke engine, always use a good two stroke oil designed for use in chainsaws, not out board oil.
Apr 17, 2011 | Homelite Garden
How much oil goes into the fuel of the homelite 240 chainsaw
please check your manual,some are 25:1,40:1 but get the mixture right as you can damage the machine.
Sep 25, 2010 | Homelite Factory Reconditioned 26cc...
Homelite trimmer zr40502
Do you have fresh gas? If so is the mix right? If you can get to the carb easy spray some carb and choke cleaner in it. Check the gap on the new spark plug. The gap should be located somewhere in the manual. The big problem is making sure that the mix is right. To much oil in gas will foul plug smoke like crazy and foul the plug and hard to start. Not enough oil and you can seize it up.
Good luck let me know if this helps.
roundo4
Aug 16, 2009 | Homelite ZR40502 Factory-Reconditioned...
I need to know the gas to oil ratio on a Homelite Versatool I inherited.
heres a link for homelite service manual
http://www.odref.com/homelite/string-trimmers/service%20guide.PDF
pg 4 states that fuel/oil mix is 50;1
2.5 oz per gallon
Thanks.
Jun 28, 2009 | Homelite Garden
HT-17 Hedge Trimmer Fuel Ratio?
I use 40:1 in mine always have works perfect 3.2oz of reputable 2 cycle oil to one gallon of fresh gas
try to find the oil that has fuel stabilizer already in it
Jun 10, 2009 | Homelite Garden
Oil ratio
Jan 17, 2009 | Homelite Factory Reconditioned 26cc...
Garden Logo
350 people viewed this question
Top Homelite Garden Experts
roeb
Randy Schumann
Randy Schumann
lnbn1975
Are you a Homelite Garden Expert? Answer questions, earn points and help others
