Looking for a owner and or service manual for my air conditioner. THe compressor stays on when unit cycles to the off mode in energy saver. Also noticed the compressor will stay on when unit is turned off. I'm leaning towards the relay sticking on but I'm having tough time troubleshooting this intermitent problem.
SOURCE: Frigidaire FAH086N1T Thru-Wall/Window Air Conditioner
clean your return air filter, and while you have the front cover off you may want to clean the evaporator as well (it's the silver grill looking thing) some compressors come off their springs during transport and will rattle for years but still work fine.
SOURCE: Thru-the-wall air conditioner won't turn on
Check for power at the plug in, if it's got power take it back under warranty.
SOURCE: Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
SOURCE: frigidaire wall unit- 4 years old air conditioner
try a fan run capacitor ,,,and the a new fan ,see if fan is stif to turn by hand if so replace fan
SOURCE: My portable frigidaire air conditioner bucket light on
The actual bucket is located inside the machine at the bottom. To access it, you must unscrew all of the screws and take the front panel off. You cannot empty it from this side so it is not worth taking the machine apart.
However, in order to empty the bucket, there is a small black plug at the bottom left hand side at the rear of the machine. Be careful when pulling out the plug because the water will immediately drain.
Good luck.
m
