Sony FD Trinitron WEGA KV-32FS320 32" TV Logo
A
Anonymous Posted on Jul 04, 2012
KV-32FS320 service mode - Sony FD Trinitron WEGA KV-32FS320 32" TV
1 Related Answer
Anonymous
  • 630 Answers
  • Posted on Jul 02, 2009
SOURCE: KV-36FV26 service mode entry
Try Display, Channel 5, Volume +, Power On in quick succession
Getting 9 blinks on Sony 32fs320. How do I fix and how do I remove cover to fix it
http://www.manualslib.com/manual/471404/Sony-Kv-27fs320.html?page=29
Toshiba model mw27h62 wont start whats the problem
It is a power supply regulator board problem.
Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
Sony model kv-32fs320 a manual
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KV32FS320&LOC=3
Sony E-support. Hope this helps
1helpful
Sony FD TRinitron WEGA, KV-32FS320... NO PICTURE/NO SOUND ...The red light flashes on the front of the TV. I have unplugged the power cord, and have allowed time to pass before re-plugging. Once I...
Just went thru the same problem with my sony kv-34. There are two IC's on the D circut board located on the left side looking from the rear. If you can solder 18 pin IC's without making a mess it is possible.If you have a friend thats real good with a pencil tip solder device. I recomend putting sockets in where the IC's were as you won't have to worry about overheating stuff next to the IC's.Do a google search: Sony led flashes ad select the second hit in the list.
Good luck
Rich
My standy light keeps flashing and every so often it sounds like its gonna come on then it dont
There's no Picture coming out from the screen???even dark-fluctuating picture???
Does it blink?how many blinks interval?
Remote sensor is not working
TRY GETTING A SKY REMOTE THEY ARE PRE-PROGRAMED TO ALL SONY TV'S
2answers
9helpful
3answers
Sony Trinitron wont power up
the red light flashing tells you and a service person why the tv will not power up . if you have test equipment to work on electronic equipment then we can move forward if not ,your tv will need parts replaced or board replaced . you dont have a failure that you can change a setting or push a reset button to repair . you will need to get in there with equipment inject signals,look at waveforms ,and check voltages . and know what you are doing with the information you gather ...the other answer you need to send it out for repair .... most repairs on this set will run 100.00-200.00 for common problems .........Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
5helpful
2answers
Sony Trinitron KV-32FS320 5 blinks
Sony KP53HS10 5 blinks
Five blinks means "Video out abnormality detection". Possible problem areas are as follows:
Video out, IC7101, 7201, 7301 and others in C board circuit.
Q510, 516, 524 (A board).
There are actually three C boards, the CR, CG and CB boards. They are attached to the rear of the red, green and blue CRTs, respectively. I wouldnt attempt to repair the set myself. I would solicite the services of an authorized Sony servicenter.
Picture fades in and out
SYMPTOMS
Distorted Video, Partial horizontal size collapsed, pop sound, or high pitch squeal.
RESOLUTION
In very small amount of cases the capacitors listed below MIGHT BE reversed on the A Boards below.
This was found at the factory and corrected but a few boards might have this miss-mount.
Capacitors C450, C616, C632, C638, and C650.
A-1302-981-A
KV-32FS120, KV-36FS120
A-1057-457-A
KV-27FS320
A-1058-449-A
KV-32FS320, KV36FS320
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
