Panasonic Viera TH-42PZ85U 42 in. Plasma TV Logo
Anonymous Posted on Jul 04, 2012
Panasonic plasma tv th-42pz85u has no pitcure and the LED light is solid red
Level 3:
Top Expert:
  • Panasonic Master 76,851 Answers
  • Posted on Jul 04, 2012
Panasonic Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14994382
Points
237762
Check this link to know the cost and availability of the power supply board to your TV. It will be best to replace it as card basis. The power supply regulator board is faulty.
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Oct 05, 2008
SOURCE: Panasonic TH-50PZ Plasma TV won't come on.
what is a UPS?? mines doing it too
Anonymous
  • Posted on Oct 06, 2009
SOURCE: my panasonic plasma tv has some error! the red led
Panasonic sent a repairman out with the correct part after telling them about the seven blinks. The unit was out of warranty. They rock. Call 800-211-7262 or 800-524-1448 1
Anonymous
  • 178 Answers
  • Posted on May 10, 2010
SOURCE: TH-42PZ80U Panasonic Plasma, red light flashes 10 times
Panasonic said "A" board,
A board SOS Detect (Explanation)
10 Blinks SOS: The voltage regulators IC5400 and IC5401 in the A board generate SUB9V and SUB5V. The 9V and 5V from these ICs are monitored by IC1100. Any abnormality on the SUB9V or SUB5V lines, triggers the shutdown circuit and the MPU shuts down the unit. The power LED blinks 10 times.
But need to measure the connection SC2, if it short, it will be the SC board.
The knowledge obtain from: Real case of repair by myself.
Information from Panasonic training manual.
Anonymous
  • Posted on Jul 11, 2010
SOURCE: I have a panasonic plasma tv. Model #
I don't know but I'm having a similar problem. I have a plasma
TH-50PZ77U. It will run for a while and then shuts off. Also, the volume goes up and up and then it shuts off at times. Like I have a ghost here. I had both of my sat. recievers replaced. It seems to get worse over time with shut down. I called panasonic and they had no info and denied this was an issue but I beg to differ from my research here online. It's only a few years and we paid lots of $$$. They gave me a # for service 1 hour away!
Anonymous
  • 10594 Answers
  • Posted on Jul 02, 2011
SOURCE: Panasonic TH-42pz85U will not turn
I'm not sure where did you find out info about 10 times blink is problem of power supply board in Panasonic TH-42PZ85U plasma tv.
In fact 10 times blinking light indicates problem with A board and possible reason are as follows..
Sub 5V missing
Main 3.3V missing
DTV 9V missing
Tuner Viltage missing
Click HERE to view error code chart of this tv that will help.
Thanks.
Have a two inch solid red vertical line center screen.....what may be problem?
If this is a pencil thin line you have a bad plasma panel. The plasma panel is no longer available.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Owners manual
Panasonic has most of their product manuals on the product support page. For the TH-42PZ85U, see http://shop.panasonic.com/shop/model/TH-42PZ85U?t=manuals&support#tabs . Look for the Owner's Manual tab.
The direct link to the manual is http://service.us.panasonic.com/OPERMANPDF/TH42PZ85U.PDF .
I hope this helps.
1helpful
My Panasonic 42 inch plasma tv randomly shuts off. when turned on it flashes 6 time pauses for 4 and flashes 6 times. Modal # is TH-42PZ85U
Check out the charts to determine the faulty part. Likely, there is a burned out component and it needs the board needs to be replaced.
2answers
Panasonic 42 inch plasma wont turn on. red light blinks 10 times
I unpluged mine and the light was still blinking when it was unpluged. I thought that was weird. So I pluged it back in and just heald the power button in untill the light went out. It went out within ten seconds. I pushed the power button again and the tv went on. WOOHOO!!! Just needed reset, I guess.
When you use a input the screen fuzzes red. It's a Panasonic Plasma TV TH-42PZ85U. It was made in 2008. Started when i was playing a game. It did it a few times and now its permanent. On the Video Inp
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Panasonic plasma tv turns on but no picture or sound
Same issue with - Panasonic TH-50PX70A , power UP with red standby, then power ON by remote - only Gives GREEN led blinking 35-40 times, followed by solid green led with no no picture no sound.
>> Solution; unplug Plasma from AC 10-15min, then plug in & power on to Red standby led,, At this point - Power ON tv while holding down both -Volume Down and F (function Select) buttons (front panel door) at the same time turns picture ON,all ok.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
