Question about Exercise & Fitness
Pulley 39437200 pulley part number 39437200
  • justin baker
    justin baker Jul 04, 2012
    where to buy replacement parts easily?
  • justin baker
    justin baker Jul 05, 2012
    FIxed this problem myself, now whos the expert!!
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 65 Answers
What is the make and model of the machine?
Posted on Jul 16, 2012
SOURCE:
Can you show me the correct diagram for the drive belt on a 44in Dixon zero turn mower
Hope this helps. Serpentine Blade Drive Belt
1 Lower the mower deck to its lowest position.
2 Route the serpentine blade drive belt (part number 6109) onto the V-pulleys located on the mower deck. One double pulley is located at the front of the deck near the center. The other two pulleys are located near each side of the deck. Route the belt around the outside -- the side toward the outer edge of the mower deck -- of each pulley. For the double pulley near the front of the deck, route the belt around the lower pulley (part number 6058) only. If pulleys are fitted with belt guards, work the belt in between the pulley and shield.
3 Push the idler pulley toward the center of the deck with your hand. The idler pulley (part number 6059) is the fourth pulley on the deck and is located near the rear of the deck. It is the only movable pulley on the deck. Wrap the belt around the side of the pulley nearest the edge of the deck. Release the idler pulley to place tension on the belt. No adjustment is necessary because the serpentine idler spring (part number 6065), located on the idler pulley, adjusts the belt to the correct tension.
May 10, 2016 | Garden
Need a belt diagram for a 03,f-150 4.2l w/ac
2002 with a/c, best I can do.
Item Part Number Description 1 10344 Generator pulley 2 8678 Belt idler pulley 3 8509 Water pump pulley 4 19D784 A/C clutch pulley 5 3A733 Power steering pump pulley 6 6B321 Crankshaft pulley 7 8678 Belt idler pulley 8 6B209 Drive belt tensioner 9 8620
May 04, 2011 | Ford F-150 Cars & Trucks
Serpintine belt diagram
what engine? Please rate if it helps
3.L v6
snorkelbobby_26.gif Item Part Number Description 1 3A733 Power steering pump pulley 2 8620 Drive belt 3 2E884 A/C clutch pulley 4 6316 Crankshaft pulley 5 6B209 Drive belt tensioner 6 10344 Generator pulley
2.0L Zetec 4 cyl with A/C
snorkelbobby_27.gif Item Part Number Description 1 10344 Generator pulley 2 19A216 Belt idler pulley 3 3A733 Power steering pump pulley 4 6C301 Drive belt 5 2E884 A/C clutch pulley 6 6B320 Crankshaft pulley 7 8509 Water pump pulley 8 6A228 Drive belt tensioner
Jan 12, 2011 | 2002 Ford Escape
Serpentine belt routing for 2001 ford taurus
what engine? Please rate if this helps. Took a lot of time to dig out.
here's 2002 3.0L 2 valve
Item Part Number Description 1 10346 Generator pulley 2 8678 Belt idler pulley 3 3A733 Power steering pump pulley 4 8620 Drive belt 5 2E884 A/C clutch pulley 6 6B209 Drive belt tensioner pulley 7 6312 Crankshaft pulley 8 8509 Water pump pulley
4 valve
Item Part Number Description 1 3A733 Power steering pump pulley 2 8620 Drive belt 3 2E884 A/C clutch pulley 4 6316 Crankshaft pulley 5 6B209 Drive belt tensioner pulley 6 10344 Generator pulley
water pump 4 valve
Item Part Number Description 1 6A359 Camshaft drive pulley 2 8K543 Drive belt 3 8509 Water pump pulley 4 8W508 Drive belt tensioner pulley
Dec 20, 2010 | Ford Taurus Cars & Trucks
Replacing belt on 2000 ford wingstar(diagram) 3.8litre engine
Item Part Number Description 1 8620 Drive belt 2 3D673 Power steering pump pulley 3 8A528 Water pump pulley 4 10300 Generator pulley 5 6C348 Idler pulley 6 2E884 A/C clutch pulley 7 6B321 Crankshaft vibration damper pulley 8 6B209 Drive belt tensioner
Aug 12, 2010 | 2000 Ford Windstar
Need diagram for a 2005 mustang 4.0 liter for serpintine belt
Hope this helps ya.. Cobra.. :-)
Item Part Number Description 1 10300 Generator pulley 2 3A733 Power steering pump pulley 3 2E884 A/C compressor pulley 4 8509 Coolant pump pulley 5 6B321 Crankshaft pulley 6 6B209 Accessory drive belt tensioner pulley 7 8678 Accessory drive belt idler pulley 8 8620 Accessory drive belt
Jun 14, 2010 | 2005 Ford Mustang
Serpentine belt diagrm
Not sure if you have the 3.0L 2V or the 3L 4V so heres both. Hope it helps.. Cobra,, :-)
Item Part Number Description 1 3A733 Power steering pump pulley 2 8509 Water pump pulley 3 2E884 A/C clutch pulley 4 8620 Drive belt 5 6312 Crankshaft pulley 6 6B209 Drive belt tensioner pulley 7 10346 Generator pulley
Jun 05, 2010 | 2000 Ford Taurus
Belt diagram
2 valve
Item Part Number Description 1 8679 Belt idler pulley 2 10344 Generator pulley 3 8620 Drive belt 4 3A733 Power steering pump pulley 5 6312 Crankshaft pulley 6 8509 Water pump pulley 7 2E884 A/C clutch pulley 8 6B209 Drive belt tensioner pulley
4 valve
Item Part Number Description 1 19A216 Belt idler pulley 2 10300 Generator clutch pulley 3 8620 Drive belt 4 3A733 Power steering pump pulley 5 6316 Crankshaft pulley 6 8A528 Water pump pulley 7 19D692 A/C clutch pulley 8 6B209 Drive belt tensioner pulley 9 19A216 Belt idler pulley
Oct 26, 2009 | 2003 Mercury Grand Marquis
I have a sanborn magna force 5hp air comp. The belt is missing and would like to know the length for replacement
The web address below will provide you with the information necessary to order a belt for your compressor. Check the model number first however to insure correct part.
http://www.mastertoolrepair.com/165tgc51b850tgb8p165tg51h850tgh8p-p-1454.html
I have replace the V belt on my compressor with an automotive type belt to save money (and better quality). I used a tape measure around both pulleys to get the length. Check the motor/compressor for adjustability as this will help when tightening the belt. If the motor/pump is already positioned all the way out, re-adjust to closed position and remeasure. Now for width of the belt; automotive belts are sold by length and width and use a common numbering system of five digits. The first two numbers printed on the belt refer to the width and the last three refer to length. Measure the width of the pulley grove. My pulley measured about 1/2" . Auto belts were available in 13/16", 15/16" and 17/16" widths. These belts are marked with first two numbers as 13 or 15 or 17. Next use the measurement around the two pulleys. My compressor measured 47 inches around the pulleys. So the automotive belt number for my compressor is 15470. If the measurement around the pulleys was 471/2" then the belt number would have been 15475. The last number refers to 1/2" either a (0) or a (5) Most autopart stores will ask you for the year and model of car for your belt but ask to see the belts with tape measure in hand and check for size using the numbering system for a guide. If your compressor uses a flat style belt you can buy from www.grainger.com. Measure around the pulleys the same way for length. Good Luck with your project.
Apr 13, 2009 | Air Tools & Compressors
Took serpentine belt off and forgot how its goes back on. 1997 ford f150 4x4 5.4
here it is
b5421bb.gif Item Part Number Description 1 6B209 Drive Belt Tensioner 2 8678 Belt Idler Pulley 3 10344 Generator Pulley 4 8509 Water Pump Pulley 5 8678 Belt Idler Pulley 6 3A733 Power Steering Pump Pulley 7 6316 Crankshaft Vibration Damper and Pulley 8 — Drive Belt Tensioner Pulley 9 2E884 A/C Clutch Pulley (If Equipped)
Apr 12, 2009 | 1997 Ford F150 Regular Cab
Exercise & Fitness Logo
56 people viewed this question
Top Exercise & Fitness Experts
Treadmill Repairs...
Tom Chichester
ray gallant
ray gallant
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
