Posted on Dec 07, 2008
Ipod nano - stopped working - will not come on anymore
I have a new generation nano. It just all of a sudden stopped working. It will not come on anymore and the battery is fully charged. I've tried charging it with the AC and USB chargers. will not turn on &computer will not recognize it.
  • dancer0283 Jan 12, 2009
    My iPod did the same thing yesterday. I actually was in a minor car accident and my iPod was plugged in but I know it was working when I unplugged it and put in my purse but now it won't turn on and it won't charge. It's a nano new generation iPod.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 20, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
590
Points
16
Hold the menu and select button for six seconds and pray it works, otherwise it may be a software malfunction.
2 Related Answers
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Sep 05, 2008
SOURCE: ipod nano - stopped working - will not come on anymore
Do the 5 R's suggested in the user's manual first. If those fail, then the player has an internal problem and needs to be replaced.
Anonymous
  • Posted on Dec 15, 2008
i had the same kind of problem...i found out i can reset my iPod
actually i did that by connecting Ipod to computer one finger from one hand to press the Center button, and one finger from the other hand to press the Menu button i did it for several seconds and for a few times..then its started again...
5helpful
You have to reset the Nano..
TO do this.
Make sure the slide switch is in the unlock position
Press and hold the centre button.
Press and hold the Menu.
After a few seconds the Apple logo should appear.
When this happensl
Let both buttons go.
The Nano should now work properly..
1helpful
Does the aj300D speaker dock charge and play the new iPod nano 4t
nano 4th does not support firewire anymore, best option is to bring your AJ300D back to where you bought it. Philips claim that nano 4th is supported is not true.
The new ipod nano
How old is it? if it's under warranty apple may fix it.
Simply, if you charge your iPod through you computer then the battery could be damaged. USB ports only put out 5 volts. If you have an AC charger that puts out 9.5 volts then consider charging it with that. Some AC adapters only put out 5 volts for the purpose matching the USB standard, but it's not good for the ipod.
Check out VaxTex @ http://www.vaxtex.com
hope this helps
The new ipod nano
depending on when you got it, i think there is a 30 day warranty but phone the store you purchased it at to make sure.
My itunes won't detect my ipod nano 4gb
well sometimes what people do is that they plug in the usb cable before the computer is on and it wont recognize the ipod. You have to turn off the computer and wait till it is on and then plug it in.
I turned on my Ipod nano and it froze..
Refer to your manual for the details - A simple reset will probably work. Running Mp3 players on low batt can cause all sorts of goofiness.
Remember these five basic suggestions if you have a problem with your iPod nano. If
one of the following doesn’t help, read on for solutions to specific problems.
â Reset your iPod nano. See “General Suggestions,” below.
â Retry with a different USB port if you cannot see iPod nano in iTunes.
â Restart your computer and make sure you have the latest software updates
installed.
â Reinstall iPod and iTunes software from the latest versions on the web.
â Restore your iPod nano. See “Updating and Restoring iPod Software” on page whatever.
-Tha Mp3 Doctor
Ipod nano 3rd generation and 1st generation nano
The first question I'm not sure. Is that the wireless network system that works with the wall outlets for power and networking?
The answer to the second question is No. You can only transfer playlists from ITunes into the IPod. Make sure your playlists are created in ITues before transferring.
2answers
Wased iPod nano--was working, now its not.
if you still have a warranty get a new one
 Grubhead
Grubhead
SmartAviator
SmartAviator
