Question about Razor E200/300 Electric Scooter Battery
Razor e200 runs slow
Battery shows fully charged (Green light) but scooter moves slow.
Checked charger and it is producing 27 volts....
What could it be?
  • 2 more comments
  • Anonymous Feb 13, 2009
    IDK!!! It's pissin me off cuz I'm tryin to sell and its being stupid.
    I've dismantled the whole thing. Still no solution.
  • fplqnewc
    fplqnewc May 11, 2010
    Is it the charger showing a green light or the scooter battery indicator on the handle bar? Also check for flat tire or misaligned rear wheel causing it to drag.
  • Anonymous Mar 23, 2014
    I bought my Son new batteries for his scooter! They were not charged when we got them. Put them on the charger for at least 14 hours and still not charged.
  • Anonymous Sep 01, 2017
    On mine it was because of not enough air in tire. Check if it goes slowly when you lay it on the side and accelerate.
    Problem Solver:
  • 7 Answers
You need a new battery they cost about 35$ on razor
Posted on Jun 08, 2009
  • 161 Answers
This could be a sign of a dying battery, although it charges and lights the green light it cannot maintain enough juice to power the machine when it has weight on it.
Posted on Mar 26, 2009
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 31 Answers
SOURCE:
I turn on my razor E300 the lights comes on to say its on but dont work i plug my charger in and on the chager the green light comes on saying its full charged what could b the prblem ?
The green light will come on if the charger does not sense a low battery. In other words, if you plug it into the wall, and not the scooter, it will still show the green light. It will only show a low charge (and charge the battery) if it is completely connected completing the circuit. My guess is that the battery is dead, and the plug is not all the way connected. Also, I believe the scooter has to be turned off to charge.
Oct 18, 2014 | Razor E300 Scooter
Razor e200
Hi, check all the connections are clean. It could be the charger is done but some batteries when they get left for a long period without charge they won't take a charge any more. Disconnect from power supply before attempting any inspection. Check the wheels are turning freely and not binding. Then last of all the motor may have to be checked.
Apr 21, 2014 | Toys
Razor e200 power scooter goes very slow
the battery is probably dying out and you need a new one, or need to charge
Jun 23, 2012 | Razor E200 Electric Scooter Green
Razor bella will not go?
one or both of the batteries must be bad, lift the seat up the remove the screws that hold the compartment down and then you should be able to see the two batteries below there, first visually inspect the batteries to see if they look like they are bulging, then test each battery with a multimeter and make sure it is showing at least 12 volts, chances are one or both of the batteries will not show more than 12 volts
May 29, 2012 | Razor USA Razor Pocket Mod Electric...
Battery charger indicating that batteries are fully charged, but battery meter on the scooter shows no power at all. also the lights, indicaters etc arent working, im presuming that is resulting from the...
With a Pride Scooter the charger will turn green if its fully charged and if there is a bad connection in the wiring with the batteries. If you plug in the charger and the light comes on green right away then there is a problem with the wiring or connections. Take a voltmeter and read the voltage at each battery. Fully charged they should be 13-15 volts each. If they are less than 12 volts then they are not charged and the charger is not working correctly. If the batteries are really low like less than 8 volts each then the scooter might not come on at all. If you find that the batteries have at least 12 volts or more then there is a wiring problem from the rear of the scooter to the front tiller. Pride has a habit of developing problems in the harness running from the rear to the tiller. My suggestion is to contact your provider (where you got the scooter) and have them troubleshoot the scooter. If the scooter is less than a year old then it should be under warranty and your provider will have to fix it under warranty. Sorry I don't have a quick fix for you but scooters are notoriously bad to troubleshoot and repair, especially long distance. Hope this helps you
Mar 14, 2011 | Pride New Mobility Victory XL 4 Wheel...
I replaced new battery but still the scooter runs slow
The Razor E300 electric scooters are battery operated scooters and can run at 15 miles per hour. This is enough to produce the best fun for kids while on their free time. It's a quiet worker, and with that speed, you won't get scared of the child going too fast to be prone to accident. Yet, it is still good to take precautions. Let the kid wear a helmet, foremost, because this can protect the head should accidents happen.
Your scooter may need new batteries, or a controller. To check these components functionality you will need a volt meter. Check the current coming out of the batteries, check the current going into the batteries and both should read in the 12.5-14 volt range. If your charger, ore the charger connection is faulty you will need wiring, or a charge port. If your batteries are faulty, you will need batteries. Check your controller with a volt meter, or a test light to see that all connections are secure and the controller is functioning properly. If you need parts or repairs done, you can visit this Electric Scooters Parts Store Online with "Find a Repair Shop" feature.
I hope this helps; remember to rate this answer.
Oct 04, 2010 | Razor E300 Scooter
My sons razor e200 dies quickly. I have changed the batteries, brought a new charger. I have checked the connectors and the tires are not flat The light is green but after 25 yds, turns and says needs to...
Problem is not the batteries then. Replace the controller. The controller could be resisting some of the charging current to the battery.
But first try this:
Charger the scooter with it OFF
Directly connect the charger to the battery
If still the same problem then:
Directly connect the charger to the battery then,
connect the motor leads directly to the battery and see how long it runs. It with new the batteries it should run longer than a minute. If it does than something is definitively wrong with the controller.
Aug 15, 2010 | Razor E200/300 Electric Scooter Battery
Razor E100 reset button and no charge
Hi... My son hasnt used his Razor E100 for nearly a year as couldnt find the charger.. I finally found it and as soon as I plugged it in the plug was showing green light as that it was fully charged... When we turn the unit on it lights up but its dead... Where can I get the cheapest battery (and does it have 1 or 2)? Or you mention a reset button? Many Thanks...
Jan 24, 2010 | Razor E100 Electric Scooter
On an E 100 Razor scooter, the battery charger shows charged
We had the same problem that I found to have a very simple fix. It seems all that needed to be done was hold in the reset button a few seconds while the battery charger was plugged in and the light on the charger turned to red and the battery charged again. Seems like too easy of a fix but it worked for my kids scooter.
Jan 25, 2009 | Razor E100 Electric Scooter
Razor E200/300 Electric Scooter Battery Logo
3,404 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
William Erickson
Are you a Razor Toy Expert? Answer questions, earn points and help others
