Insert into disk into camera received error message "Memory Card Error" then "Card Locked". I have check the slide button on the side of card it is in the unlocked position. I have attempted to format the disk while in my camera but that option is greyed out. Is the disk defective?
If you just bought this card, send it to the seller for a replacement. Or you can try to Remove Write Protection from SD Card by yourself.
SOURCE: I have a 4.0 GB
Yes it sounds like the disk is defective and I have seen these bad so its definitely the most likely possibility. Sounds like the switch itself to unlock it is bad. Good luck and thanks for using fixya, please take a moment to rate my solution I hope you fin it fixya appropriate.
Thanks,
Lee
SOURCE: Problems with SanDisk 4GB Cruzer. looks good at
Okay, Can you tell me the model of your computer?
Ryan Frame
Creative Energy Associates Technical Center
Head Technician
i can not down load pictures on computer sandisk 4.0
