- Of course there is water in the tank. - Already tried with hot water, but the machine only gives steam, no coffee or hot water. - Already switched it off for 24 hours. (unplugged) Please help me with this problem. Thanks!
SOURCE: My Jura Impressa xs90 keeps stating fill system,
Empty the Water tank and fill it with warm water. Then keep trying for some time and the problem will get solved.
SOURCE: Jura Capresso Impressa S9- no steam
I had a similar problem. I took off the side and rear cover, followed the hose that comes from the steam wand to the rear of hte unit. It enters a solenoid made by ACL Italy. I dismantled the solenoid unit by disconnecting the two hose ends, removing the relay, and unscrewing the plunger unit (vertical pipe). The plunger unit internals should move freely up and down like a piston in a cylinder , powered by a small spring. In my unit, this plunger was calcified and seized. I soaked it in boiling water and pressed on it gently several times and it unstuck. I put it all back together again and presto! Good luck
Thanks for your suggestions, unfortunately it didn't work out. The hot water outlet for tea is not working either.
Any other suggestions? Thanks in advance.
