Question about Haier Refrigerators
Deep freezer not freezing food and keeps making a clicking sound.
I have a Haier deep freezer model number HNCM053E that keeps making a clicking sound. My lights work on the front of the unit but it won't freeze the food. I checked the compressor model number GVY44AD R134a to see if the compressor needed to be charged but it's a sealed unit. Can you please help me?
    Top Expert:
  • Haier Master
  • 54,195 Answers
Even a sealed unit could need recharging with R134a refrigerant.
Posted on Dec 30, 2017
SOURCE:
Sea Breeze
  • 4656 Answers
SOURCE: freezer stops freezing
How long has this happened and when did it begin. Your refrigerator has a control board located on the back inside a panel. You may need to unplug and look for burns on that board. Let me know for sure that the model is HSM25GFTSA
Thanks, Sea Breeze
Posted on Mar 22, 2009
  • 700 Answers
SOURCE: Freezer is not keeping food frozen, and is making a clicking sound. The sound seems to be coming from the computer board on the back of the unit.
sound like the starting relay may be bad, get a 3 in one relay and replace the components
Posted on May 21, 2009
cj2176
  • 520 Answers
SOURCE: ice on back wall but not freezing food and rattle noise. Moved all food to other freezer
This is a fairly common problem with these types of refrigerators. The design is set to defrost every 12 hours and be down for 1 hour to allow ice to melt on coils. More often than not the ice never fully melts and creates a blockage in the coils and in turn slows air flow. You can remove the screws in the back wall of freezer unit and unsnap the ice maker plug to allow access to the coil. Gently tilt the back plate forward. You can then unplug the ref. and help it thaw with a blow drier. If you are not comfortable removing the back plate then you can just unplug the ref. and let it thaw on its own. this may take a while. try to remove as much ice as you can from the back of the freezer wall by hand and prop the door open for a couple of hours to ensure that all the ice melts. The rattling sound you are hearing is the fan blades hitting the ice that is built up around it. As a precaution I recommend that these type of refrigerators get manual defrost simply by unplugging about once a month for about two (2) hours. I hope that this will help you out with the melted ice cream. Good luck.
Posted on May 30, 2009
  • 52 Answers
SOURCE: Unit stopped cooling and freezing & have recurring clicking noise
sounds like compressor motor is gone ...call tech
Posted on Jul 26, 2009
milten1
  • 1304 Answers
SOURCE: fridge not cooling, freezer not freezing, buzzing sound
with any luck this is you overload and relay
it is the plug on the actual compressor, this is very easy to replace, if you replace it and it does exactly the same thing its your internal relay and your compressor is done....
Posted on Oct 03, 2009
Testimonial: "thank you...I removed the relay/regulator to find it rattled and found burnt marks inside. I found them online, am waiting its arrival now."
Can i defrost a piece of beef cook it slice it then refreeze it
Yes you can. If it is roast beef you might want to freeze it in beef gravy. Make sure it is sealed real good and use freezer plastic bags or if you have a food sealing device to vaccumm seal it. Deep Freeze meats cooked or uncooked last longer in a Deep Freezer as well!
Oct 13, 2014 | Refrigerators
Haier 5.3 Cu ft Chest freezer. power is on but compressor doesn't run. There is click sound but nothing happens after.
The click sound is the compressor starter relay closing but if nothing further happens it is likely that there has been a compressor failure
Apr 11, 2013 | Haier 5.3 cu. ft. Chest Freezer HNCM053E
Compressor doesnt run
Feel the top of compressor. Is it too hot to keep hand there? Is this the freezer? HERE Let me know, Thanks Sea Breeze
User Manual HERE
Dec 08, 2012 | Haier HNCM053E Chest Freezer
Deep freeze compressor not kicking on.
Sounds like the relay contacts are staying open.
Jul 29, 2010 | Haier Freezers
MAKING A LOUD CLICKING SOUNDS
Hi, I am not familiar with this model but the noise sounds like a relay clicking at the compressor. Is the sound coming from the outside in the back?
Please let me know if I can assist you further.
Thanks
Vic
May 24, 2009 | Haier 9.1 cu. ft. / 258 liter Upright...
Same problem no solution not sure but need help bad fridge is getting warm
Not cooling at all? or other symtoms that can help us get you going. Can you make sure the refrigerator is listed as Kenmore
Here are some examples of model numbers for this appliance: 106.8782070, 596.58692890, 119.909851, 119.3101279, 198.887482, 253.835123
•  Inside the refrigerator or freezer, on the upper left or right side wall
    •  Behind the lower crisper drawer
    •  Behind the lower toe kick-plate
    •  On the face frame of the refrigerator body
Can you help locate these numbers so I can assist you with the drawing of that door?  TKS,Sea Breeze
Oct 24, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
275 people viewed this question
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
