SOURCE: replacing hopper after cleaning
The hopper has two slots in the bottom that aligns with two black tabs in the base. Rotate the tab ring in the base counterclockwise and then install the hopper.
SOURCE: I cleaned my Breville grinder
This might be it. On the bean container there is a white dart and the word 'align'. The same dart and word appear on the top of the grinder. Align the two darts and the bean container should drop right in.
SOURCE: I cleaned my Breville grinder and tried to put it
This is happening to me too. Did anyone solve this issue? How did yours get fixed? Thanks!
SOURCE: Because it seemed to be
The manufacturer never made any parts available means the manufacturer never released any exploded views either. No need to create/publish parts diagrams if no parts are going to be sold. Sorry.
As far as your lost ball bearing, you may be most successful at a bicycle store. They commonly handle loose ball bearing and, if they are good, should be able to measure one for you and sell you a replacement. Most hardware stores only sell bearings that are sealed or in a set (cage). Most autoparts stores are also limited to cage bearing sets.
Good luck getting it back together. However, if it needed to be taken apart and the manufacturer views the product as "disposable" (since they don't sell parts), then you might want to limit your anger and losses and just buy a replacement grinder.
-Mark
