Sony FD Trinitron WEGA KV-27FS120 27" TV Logo
Posted on Jul 03, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i turn on my tv it keep turn off and blink 4 times the red led, what that means?
Level 3:
Top Expert:
  • Sony Master 76,851 Answers
  • Posted on Jul 03, 2012
Sony Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14993353
Points
237762
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505. This is the fault. Check all the solder terminals of the vertical output IC first. Loose soldering terminals to this IC can poise this type of problem. Resolder all the suspected solder terminals to this IC. If this do not help you, replace this IC with same number.
5 Related Answers
Anonymous
  • 4234 Answers
  • Posted on Oct 01, 2008
SOURCE: SONY WEGA KV-36HS420 will not come on
The blinking is an indication that the set detected a problem. The code usually indicates a bad regulator circuit. If yu can solder, you can probably fix this your self. Please let me know if you wish to attempt the repair. If not, expect a parts cost in the $25-$40 range plus the local labor rate for the repair.
Anonymous
  • 168 Answers
  • Posted on Jan 20, 2007
SOURCE: TV not working
the symptom is usually caused by a breakdown in the power supply circuit. in most modern receivers (transistorized and/or ic), it may also be caused by a breakdown in the horizontal deflection circuits (hor. oscillator, pre-drive, or drive circuits). supply voltages for the tuner, video if,sound if, and vertical output are usually supplied by the horizontal output circuit. but if you doesnt know anything about these stuffs, better bring it to a qualified service tecnhician.
Anonymous
  • 1139 Answers
  • Posted on Nov 23, 2008
SOURCE: KV-36XBR450, FD Trinitron WEGA
Hello maymet,
This sounds like the HV protection circuit is cutting off the TV due to a high current event in the set. This could be a problem in the High Voltage section of your TV (Horizontal output transistor, Integrated High Voltage Transformer, and y of the deflection components, and or the CRT in cases of shorts).
I would suggest that if you do not have a background in electronics, you should have an experienced TV technician troubleshoot and repair this problem.
This is due to the nature of the dangerous voltages that are present in the television.
I hope this helps,
Thank you,
Shuttle83
Anonymous
  • 76 Answers
  • Posted on Dec 03, 2008
SOURCE: No Picture or sound, red standby light blinks six times
Sorry for how long it is but you should be able to find what is wrong in this guide
If you have any questions please dont hesitate to ask
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby
mode then displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with
the video. Check video out, Q705, 732, 761 and other components on the C
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and
blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
Intermittent problems ?? This is a great feature. You can also bring up
these fault codes ON-SCREEN to see a list of the problem numbers with the
abbreviation of the problem and the number of times this problem has
occurred. This is slightly different than entering the service mode. To see the
diagnostic screen, Press the following buttons:
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up
a screen with a list of the problems and number of times they have occurred.
Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
We have repeated them in parentheses in the text for the "Blinks" described
above so you can correlate between the diagnostic screen and the blink
codes.
So, now that you know about these self-diagnostics, how do you use them?
Say that you have a set with a black screen. You see that the LED is blinking
4 times....This would tell you that you have no vertical and that is why the
video is muted. If it was blinking 6 times, you would know that you have a
horizontal fault.
It's not a sure cure, but it's a little better than a poke in the eye with a sharp
stick.
IMPORTANT: after you repair the unit, PLEASE clear the values on this diagnostic screen. These codes do not reset themselves after the fault is 0 corrected, so if you don't clear them, you'll be seeing "old" fault codes the
next time you enter this screen. Clearing is done by going into the service mode ( display, channel, 5, volume plus, then power ) then press 8 and Enter, which of course returns
everything to the factory preset condition.
Anonymous
  • 6784 Answers
  • Posted on Jun 21, 2009
SOURCE: TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
1helpful
My sony bravia tv wont turn on. The light just flashes red but the tv will not turn on
There is a system error then. If a red LED is blinking and the TV is not working properly it means that the TV has detected an issue or problem. Most of the Red LED blink conditions will require being service. Check how many times the red LED light will blink and then contact Sony for support.
2helpful
When i try to turn on my sony kv-27fs12 keep turn off and blink 4 time a red led make a pause and keep blinking 4 times, what that could be?
Vertical sweep failure. Check all the solder terminals to vertical output IC. If it do not help, replace that IC.
TV turns itself off, then on automaticlly
The fan should run for a few minutes after shut off to cool the lamp down.
If I read and understand correctly somewhere in the cycle you are getting 5 red blinks? that is an error code........
Either you or I can Google the model number of the set with 5 blinks.....or visit the Sony site to see what it means.....
Tele turned itself off, red light blinks 4 times then pauses and blinks 4 times again.
You can try unplugging it for a while and then plugging it back in, but according to the manual, the standby LED:
Lights up red when your TV is in PC power saving mode. If the LED blinks in red continuously, this may indicate the TV needs servicing.
(Operating Instructions, Page 22)
9helpful
3answers
Tv won't turn on 4 blinking led
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly.
Thanks.
Sharp 42" aqios failure. Power led blinks red aprox once a sec. I have truned the power off waited 1 hour. Pluged in the power again. Turned the tv on on the right side of the screen. Power turns on power...
blinking red mean there is problem on one of the boards. it s a computer so it is stopping it to keep it from burning something up the 2-4 seconds is a system check.
1helpful
Tv wont trurn on
Re-check the lamp door alignment. If the door is not installed properly, the interlock switch will open causing a no start condition. Also observe the red LED on the front panel. When you turn on the TV, a gree LED will blink on and off until the image appears. If the image fails to appear the green LED will give way to a red LED that will flash a specific number of times in between pauses. 3 blinks means the door is not installed correctly. 4 blinks means that a fan has stopped working, etc.
michtech
2helpful
Tv wont turn
The blinking red light at the the front of the television is the "Diagnostic STANDBY/TIMER LED".
This little red light will blink 2, 4, or 5 times and then stay off for three-seconds. And blink again for 2, 4, or 5 times. This cycle repeats. The most common diagnostic code is the 4-blink code.
When the red LED blinks 4-times, it means one of two possible causes:
1) +13V is not supplied on the A-board. Or, 2) IC502 is faulty.
It is best to take this television set to a repair facility and ask that the +13V power supply be repaired.
The copper tracks and integrated circuit pads are very thin and delicate on the KV-24FV12 circuit board, and will easily lift off of the circuit board, if the incorrect desoldering tool is used. Unless one has a good quality PACE vacuum desoldering unit, one should not attempt to repair the television.
1helpful
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
