C1800
SOURCE: I have a Nordic Track treadmill C1800. When first
You have 1,2 or maybe 3 problems. 1st is you need to remove the cover over the motor. The belt that the motor turns may be slipping. You need to loosen the bolt that keeps the tension on the drive belt. Push down to tighten manually and then tighten bolt. While your in there you should check the drive belt for wear. If you have used the treadmill a lot it may need replacement. $20 from readmilldocter.com The walking belt if badly worn can be replaced for like $99 but probably is fine. put all back together and tighten tension. Should be able to lift walking belt 3 to 4 inches from center sides. Any less and its too tight. Its probably better to just replace the drive belt anyway. This should work. Do not over tighten ever. This is the cause of most problems.
SOURCE: NordicTrac C1800, Motor quits in less than 1 sec, console pwr ok.
motor controller shorted see me at mc70repairexpert.com
