I had kept my iPhone 3G for charging on the floor and the next minute it began to say No Sim. Removed and replaced numerous time the sim card and still No Sim error message. Then reset and restored to factory setting and jailbroke the phone using Pwnage 2.2 and still No Sim Card Installed. Also I see that ICCID has no value.
Check your ipphone by IMEI in www.imei.info my by it was blocked for some reason. Check sim without jailbreak. Try another sim, my be your sim is broken. BEST WAY TO GET TO KNOW YOUR PHONE BETTER
SOURCE: Iphone 3G blocked after Mishap
Download redsn0w. Also, if you are talkin about holding the option key, then i'm assuming you have the ipsw file already. Jailbreak the phone using redsn0w, and then through Cydia (which will be on the iphone after jailbreak) get and install ultrasn0w. If you have any questions about detailed unlocking instructions, send me an email. And I'll go into more detail.
SOURCE: Hi I have an iphone 3g that I unlocked and
Your phone has been relocked. It will need to be hacked again.
SOURCE: Iphone Unlocking Problem
hi,try this way.cydia hit MANAGE,go to sources,you will see repo666.ultrasn0w.com,please instal it,if you did try reinstal..it will work.good luck
SOURCE: My iphone 3G relocked and factory restored
If you connect your iphone to itunes it will walk you through reactivating your phone.
