The neutral drive pedal fell off while vacuuming. There is a pedal and a small metal ball. I can't tell how to put it back together again.
This is the Exploded Parts Diagram.
https://www.partswarehouse.com/Kirby-Ultimate-G-Diamond-G7-Upright-Vacuum-Cleaner-s/2818.htm
It is a common fault. There is a video here
https://www.google.com/search?q=how+to+fix+a+kirby+vacuum+neutral+and+drive
SOURCE: I have a Series G
http://www.vacpartswarehouse.com/category-s/99.htm?gclid=CPScgteG0KgCFQEKbAod8x8QiA
This should help
Best of luck
SOURCE: The TechDrive Pedal on my Kirby G6 fell out of the
The pedal drive fell out . Do you have a manual telling me how to get it together again.. Thanks, Dianne
SOURCE: kirby neutral/drive pedal
just go to your local kirby vacuum shop or a vacuum shop.they can help you.
SOURCE: Green light on power nozzle of Kirby vacuum, Model G7D
The green light is just to inform you that the brushroll is spinning. there is a magnet on the brushroll that makes the green light come on every time it rotates. also why it looks like the light flickers because the magnet only makes contact once per rotation of your brushroll. Let me know if you have any other questions.
I had the exact situation! Thanks to "Anonymous" for the link. It was exactly what I needed!http://www.vacpartswarehouse.com/categor...
