I need to know the configuration for the fuel lines
SOURCE: need a diagram of the
You can View a Diagram of the Chainsaw here http://hayward.arinet.com/scripts/EmpartISAPI.dll?MF&app=ASP〈=EN&TF=Mainfram...
Select the Catalog Poulan/Weed Eater. Then Select Poulan. Then Select Gas. Then Select Saw. Then Scroll Down to your Model Saw i.e 2150.
Regards
Marc
SOURCE: NEED A FUEL LINE DIAGRAM FOR POULAN 2250
The smaller size line comes out of the tank, leave enough to install filter on that line in the tank, this line goes to the intake side( I think it is the right side of the carb when it's mounted in the saw), of the carb. The other smaller line goes from the other side of the carb to the primer bulb. The larger line goes from the other side of the primer bulb back to the tank, it only has to be pushed in the tank about 1/2 to 3/4 inch. The large line goes in the tank in the hole on the right side unde the carb. The primer bulb has different size nipples. I just put these on mine, it's hard to get the lines in the tank, I sprayed mine w/wd40 and just pushed them in until I could pull it with some needle nose pliers or hemostats.
SOURCE: fuel lines have rotted off. need to replace then
Mr Tittle;
It isn't good but it's all there is.
What little fuel system system detail there is can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
If it is a 2375 WildThing find 2375LE Gas Saw Type ?. The last digit of your serial number should be a -1 or -2, the type.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
HTH
Lou
SOURCE: I have a Poulan 2375 chainsaw. The fuel lines
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. It does show components and part numbers. Find it here:
Poulan.com
The dash number of your serial number is the type.
Typical fuel System:
