I have just bought a beko D533 free standing cooker and when wired in only the oven and one hob work but if you change the wiring over to the other small part I believe it's called a link three hobs and the grill work. Someone mentioned that it may have been wired incorrectly.
Please can you help
Where the power goes in there should be fuse links on both sides if they all in then its the thermal fuse inside
Is the cooker a new one? I fit is then it does sound like an internal wiring problem, in which case you should contact the supplier. Make sure it is wired correctly from your circuit breaker first, There should be a diagram showing the connections.
Hope this helps.
Please leave feedback.
Thanks but we have been told that the two links which operate each section ie the oven and one hob or the grill and the other three hobs should be linked together. Is this correct as beko will charge us if it hasn't been wired correctly.
