Broderbund The Print Shop 20 Deluxe for PC Logo
Posted on Jul 01, 2012
I can't register my copy of of Print Shop Deluxe 20
I bought this software when it first came out about ten or twelve years ago. I LIKE it...but I only have the three disks from the package, as opposed to the package itself. I wrote to Broderbund for customer support, but they sent an automated response saying that the software is too old for any support (even just regular email!) for the product. This software was my favorite to use for making cards and banners and it USED to work just fine on my laptop, but since I was forced to reformat my hard drive, my attempts to reinstall from the CDs all come up with a demand for some code that I no longer have. I want my PrintShop 20 back! Help!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 28, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
336
Points
I can't install my old verson of print shop on my new laptop.
3 Related Answers
Anonymous
  • Posted on Jan 11, 2009
SOURCE: error unabling access to printshop pro 20
TPS Window Appears on Print Shop® Splash Screen Description Solution When attempting to open Print Shop® 20, a TPS window opens on the Print Shop® splash screen. The only option available in the small TPS window is to click OK. This issue occurs when Microsoft® .NET Framework 1.1 has been uninstalled. Reinstalling Microsoft® .NET Framework 1.1 will resolve this issue. View the remainder of this technical note for the instructions. Complete these steps:
  1. Close all windows and programs and return to the desktop.
    NOTE: If the TPS window is still open on the desktop, click OK. The Print Shop® splash screen will close.
  2. Insert the Print Shop® 20 DVD or Install CD into the proper drive.
  3. Double-click the My Computer icon. For Windows® XP, click Start and click My Computer.
  4. Right-click the CD/DVD icon that represents the drive where the disc was placed and click Open. The contents of the disc will display.
  5. Double-click the Setup folder.
  6. Double-click 1033dotnetfx.exe. The installation of Microsoft® .NET Framework 1.1 will begin.
  7. Review the License Agreement, click to place a dot by "I Accept" if the agreement is accepted and click Next.
  8. Click Install to install the Microsoft .NET Framework 1.1.
  9. When the "Installation of Microsoft .NET Framework 1.1 is complete" message appears on screen, click OK.
  10. Launch and use Print Shop® 20.
Anonymous
  • Posted on Oct 12, 2010
SOURCE: Purchased Broderbund Print Shop 23.1 Deluxe. Two
Yes, otherwise you have to manually insert the Art disc every time you want to use the Art & Photos.
Rinoo Kumari
  • 2973 Answers
  • Posted on Nov 20, 2010
SOURCE: I have a Dell Inspiron
Can you try to install the PS on a different laptop or a pc? This is just to check if the package is not corrupt due to bad sectors on the CD or some kind of HW incompatibility. the installation will tell you more.
I have the full version of print shop deluxe22 and it won't let me install it on my hp laptop HP G71-442nr Notebook, Running windows 7
Print Shop 22 Deluxe is not compatible with Win 7 (x86 or x64bit) Operating.
You have to use the Print Shop 22 Deluxe version 23.1 - compatible with Win 7 & Vista.
Hope it helps.
2answers
I am currently using both Print Shop 5.0 Premier and Print Shop 10. I am switching to a new computer with Windows 7 and will need to install Print Shop 23 Deluxe. Will I be able to retrieve all the files...
I will advice you to locate the print-shop folders that are on your computer. or simple open one of the files you created with this software and right click file location. it will open where all the other files are stored on your computer. backup everything stored on your computer to a flash drive.
Let me know if this solution helps.
I purchased printshop 20 deluxe and installed on my computer which has windows 7 installed on it. The installation shows it was successful however when I try to run the printshop program it tries to start...
The Print Shop version 20 Deluxe for PC is not compatible with Windows 7. The newer Version 23 is compatible. This is due to software compatibility issues with Windows 7.
You can check for Win 7 Compatibility for "software or hardware" @ Windows 7 Compatibility Center
It will not run on Win 7, even when you are using the Compatibility Mode options. Too bad you have to get the newer version 23.
Hope it helps.
1helpful
2answers
Print Shop 2.0 Deluxe will not load.
Have you tried installing them in Compatibility Mode? If not, look in
Vista's Help
& Support for how to try this. If that doesn't work, you can
try installing them as Administrator by right-clicking on the installer
executable and choosing "run as Administrator".
If none of that works, I'm sorry but you'll need to update to a current
version of the program that the mftr. says will work in Vista.
Can you run print shop 20 deluxe from an LUA Account?
yes it is but before continuing to install print shop by other account make sure that your account is not limited access to install...
1helpful
Using alt key to type in spanish letters with puncuation
you can always use character map. Go to Start Then All Programs
Then Accesories
Then System Tools
and you will find character Map choose the letter you want and copy it & paste it =)
Top Broderbund Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
