I have power coming in to the compressor but when pushing in the door switch i get nothing
SOURCE: haier aficionado model AES44BPG compressor wont stay on
I had the same problem. Mine turned out to be the PTC starter. Checked the compressor coil resistance and it ws fine. Replaced the PTC starter with Item #: 1268268 from Repairclinc.com and it started right up. The PTC starter was an exact replacement.
Hope this helps some else trying to solve this problem. To bad Haier doesn't offer this part!!
SOURCE: Refrigerator vibrates when compresor comes on
Hi, It sounds as though the compressor has a broken valve or rod making noise internally. The compressor should be quite. You can hear them run but not enough to bother you at all. I have never heard of any of the newer ones having a compressor that supposed to be louder. Sounds as though he didn't want to do anything I don't know. I cant tell you how to check it as you would need to put a set of manifold gauges on it to see if it is working properly. If it continues, I would make another call for free of charge and have them back out! Keep me posted,
Shastalaker7
SOURCE: My Haier compact refrigerator won't turn on
A new thermostat is required. When you turned it down you probably broke the contact and will not re-connect. Be careful installing the new one the fine tube contains gas which is temperature sensitive. do kink or break it.
SOURCE: I have a Aficionado refrigerator and the
The clicking is the sound of the Klixon (overload). It sounds like the compressor isn't starting for some reason. This is common if the unit's cycle was disrupted (such as a power disruption) as the pressure in the high and low side takes a little while to equalize. A hard start kit could be installed which adds a capacitor to the starting circuit of the compressor might help temporarily.
SOURCE: Haier Model HRT02WNC compact refrigerator not cool...
this model is thermoelectric and has no gas in it.
It uses a peltier junction to provide a temp differential. the fan will run constantly, and it will cool the interior to about 35 degrees F below ambient. theoretically...
