Question about M-Audio Fast Track External Sound System
Sound coming through computer speakers instead of through fast track.
The sound will not go through the fasttrack so I can listen to my recording through my headphones. Instead the sound comes through the computer speakers. It still records my microphone though; so how do I fix this problem? Thanks SK
    Scholar:
  • 121 Answers
Check your audio settings to make sure that it's going to the right driver. goto: start -> control panel -> sound and audio devices out of the 5 tabs, you'll want to pay attention to 2 of them, these are the "audio" and "voice" tabs. Make sure that your speakers on are the external sound system's drivers and not your internal sound card. (Basically, make your sound playback the same as your sound recording)
Posted on Mar 28, 2007
SOURCE:
Why do i hear some sort of static whenever a sound comes through my fast track, but doesnt happen when im just listening to sound straight out of the computer?
Open up your computer to check usb connection make sure the connection is good and dust free
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
be sure to wear an anti static earth strap before touching anything inside your computer
hope this helps
Mar 06, 2011 | M-Audio Fast Track USB (FASTTRACK) Audio...
My m-audio fast track usb interface has been working but all of a sudden lately my computer recognizes it when I plug it in but the interface will not pick up a signal from a direct line or from a mic so I...
Hello, try going into Sound & Audio Settings through control panel. From there, click on the Audio Button. Toward the bottom on the left, UNCHECK the box that says 'USE ONLY DEFAULT DEVICES'. Then Under RECORDING section, pull down the drop menu and select M-Audio. And Click APPLY & OK to close. I would reboot and it should be working after that.. ok? Good Luck & PLEASE DON'T FORGET TO RATE MY SUGGESTION, OK? THANK YOU :)
Oct 19, 2010 | M-Audio Fast Track USB (FASTTRACK) Audio...
My computer crashes whenever I disconnect my fast track
Shut it off using the USB off icon on the lowest task bar on the right side.
Jun 17, 2010 | M-Audio Fast Track USB (FASTTRACK) Audio...
There is a 1 second delay from the time i play to
adjust your audio buffers, if your recording software allows it. however, there will always be some latency in usb recording devices. i recommend firewire or pci internal cards for recording.
Nov 30, 2009 | M-Audio Fast Track USB (FASTTRACK) Audio...
M-audio fast track sound only coming out of right side
I havent played with acid a lot... but this is what i can tell you... most of the softwares have configurable inputs... seems like your inputs are configured as stereo input and hence it will pick up the signal from both the left and right discreetly... which means that you would need to feed audio to both the channels for the meter to pump on both bars...The other option is to PAN the track center and not hard left right... this would get audio to both ears of headphone as well as the output meters...
these are basically some of the few things tht will get u sound on both ears and bars...
The bigger question here thoug is why do you want to record in stereo?? and not mono?
Jun 29, 2009 | M-Audio Fast Track USB (FASTTRACK) Audio...
No sound recognized in Audacity from Fast Track M-Audio
First thing is what operating system is on the computer.
Second is what does device manager say about the recording interface?
Third in audio properties from the task bar icon, what is the default device for recording?
Feb 23, 2018 | M-Audio Fast Track USB (FASTTRACK) Audio...
Sound in one ear only
The Fastrack only has one audio input signal to the PC. You'll need to set your recording software to mono, then you can add stereo fx in your audio software.
Jun 06, 2008 | M-Audio Fast Track USB (FASTTRACK) Audio...
M-Audio Fast Track External Sound System Logo
137 people viewed this question
Top M-Audio Computers & Internet Experts
Thomas F. Schneider
John Bolton
bigdaddyd2
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
