Error Resource Conflict - PCI Serial Bus Controller on Motherboard Bus:OE, Device:06, Function:01 Error Resource Conflict - PCI Serial Bus Controller on Motherboard Bus:OE, Device:06, Function:02 Error Resource Conflict - PCI Serial Bus Controller on Motherboard Bus:OE, Device:06, Function:03 . . . anybody help me please ?
SOURCE: Resource Conflict - PCI on Motherboard Bus:0A, Device:09, Function:00 = CARDREADER PROBLEM
I did try all that, and it didnt work, on a 5050 acer built on a 3100 gabinet.
I think that the problem is that the cardreader chip is not well glued to the motherboard, that's why it gives you that error. If you try pressing certain points of the computer while booting, it miraculously stops giving that conflict error.
We should be payed back by Acer, as this is an project issue =P
SOURCE: toshiba a105-s4054 won't boot
The
same machine with me and the same problem I changed the BIOS of the
motherboard but the problem Tlch the same message is is the last day I
discovered that the problem in the chip of Intel's motherboard happens
is a conflict between the PCI and Ridr and some of the various
components that vary according to the case of the slide as
this occurs in the organs contained in the slide as happens conflicts
in the delivery at the beginning of operation of laptop and since all
the inconsistencies that occur when you start up that is stored on the
memory the BIOS and therefore must be emptied this memory so that the
laptop from work and not doing a re- choose to run the key F-1
s this memory chip in it's protection for the BIOS that is stored by BIOS password
Points
for this memory on the motherboard when you connect to these points is
clear all data from storage on a slide in the Model 100 is a satellite
point of discharge under the Wireless card under the keyboard and be
written next to 88 **
As for in this model are under-Ram
