Sometimes loses power and starts beeping. has 6 batteries and is around 10 yrs old.
Https://thegolferadvice.com/best-golf-cart-batteries-8v/
SOURCE: 1982 e-z go electric golf cart needteck sheet.
I have a 96 EZ GO gas golf cart with loose steering. What parts are normally needed to correct this problem and are special tools required for me to replace the parts.
Thanks,
Bob
SOURCE: NO CHARGE GETTING TO BATTERIES
If your batteries aren't holding a charge then they might need to be replaced. When batteries are used seasonally their life span is generally shorter. You can check them using a voltmeter. If you need a replacement you can check out www.batteryinternational.com or call 1-877-28-BATTERY if you are having difficulty finding the battery you need.
SOURCE: I need a wiring diagram for a 1986 ezgo golf cart,
use this link http://www.vintagegolfcartparts.com/cgi-bin/gallery/gallery.cgi?func=show&file=200332&Category=100013&Page=1
SOURCE: Rear axle fluid for 1983 ez go electric golf cart?
Regular 90 weight gear oil. Fill until it reaches the fill hole.
Hank, The cart man
36volt
