Question about Water Sport
Have a 2007 yamaha FX HO Cruiser waverunner. Was riding when oil light and alarm came on and ski shut off. Husband checke oil and it was 1 & 1/2 qts low. When we restarted, it was louder than normal and wouldn't idle. He would accelerate but when letting off gas it dies. He changed all plugs because he overfilled with oil and he also cleaned the air filter bc it was full of oil. When restarted it smokes and still dies at idle and is only running at 1/2 throttle. He said it seems like it is losing power and doesn't accelerate very well or not as good as our other ( we have 2 identical skis). It is in l-mode but we just got these and are unsure of what L-mode means. Help!
2 Suggested Answers
SOURCE:
SOURCE: YAMAHA FX 1100 HO 2006 ROUGH IDLE WAVERUNNER
I have a Yamaha fx 1100 that starts real slowly the battery is fully charged but the bike sounds like its not got alot of power going to the starter can anyone help solve this also battery terminals are clean and not corroded
Posted on Jun 30, 2010
Why does yamaha waverunner fx cruiser ho not run in lake but will run hooked to water hose
Sounds like you have a bad stator. It may be producing enough spark to start the motor, but under a load (as in the water) it simply can not supply the amount of spark needed. Sometimes when a stator is tested on a ohms meter it may test good, but still be defective do to the load it will come in contact with when put in the water.
Jun 29, 2014 | Yamaha 12V Air Pump
Yamaha waverunner fx cruiser sho
check impellor blades not bent ! scoop grate not bent ? wear ring not badly worn ?not got some rope or debrise on impellor ?
May 26, 2014 | Boating
2004 waverunner fx cruiser, ran great last time out. Now hard to start and wont run on high speed. Nothing over 6 mph.
How old is the fuel? Ethanol causes major problems if left too long. You may need to empty the fuel and clean out the fuel system. Try changing the fuel filter and adding some seafoam to the fuel and running seafoam thru the fuel system. Hopoe this helps.
Mar 15, 2014 | Covercraft UltraTech Custom PWC Jet Ski...
Won't start
Fuses in the electrical box?
Jul 18, 2013 | Yamaha 2006 WaveRunner FX Base
Yamaha waverunner won't idle and losing power
L stands for limp mode
it is a mode that the ECM selects to prevent serious damage to the engine ( from you lack of oil )
have the fault codes read then reset with the scan tool
Mar 31, 2017 | Water Sport
2004 fx CRUISER ho WAVERUNNER DOESNT WANT TO IDLE OR RUN AT TOP S
did you mean 900 cause 9000 is overrived and the engine may be blown
Jul 08, 2010 | Boating
I have a 2006 yamaha waverunner fx cruiser and after about 5 or 10 mins of driving it the warning light blinks and the alarm sounds? How do u find out what causes that stuff and how do u fix it?
What does the alarm (display) say is the problem? Normaly you will get a specific error like Water TMP or Exhst. I am guessing exhaust and with that it is most likely the catalytic converver has become loose and lodged further down the exhaust.
May 20, 2010 | Yamaha 12V Air Pump
Jul 28, 2009 | Yamaha 12V Air Pump
I am on vacation and wish to activate the L mode on my 09 yamaha fx HO cruiser , how do I activate this from the remote?
u need push on the remote the l mode when the ski is not running it work just **** a alarm remote make sure the battery is good because those remotes batterys go bad quick
Jul 03, 2009 | Yamaha 12V Air Pump
My 2005 Yamaha FX HO Waverunner runs smoothly, but will only go 38 to 40 mph. The RPM Limiter is off, intake is clear, oil level is good and air cleaner is ok. Should I replace the spark plugs?
yes yes yes the new yamahas foul plugs like crazy i dont know if it is a valve defect or what but you will be changing them every year one trick i have been doing to my coustmers watercraft and has been working well insead of ngk cr9eb plugs use a cr8eb it is a hotter plug there for it will burn better and no it will not hurt your ski trust me i have over 15 yrs ex and 6 in r&d research and design
Jun 26, 2009 | Yamaha 12V Air Pump
Water Sport Logo
2,310 people viewed this question
Top Water Sport Experts
Marvin
Marvin
Tom Chichester
Bill Boyd
Are you a Water Sport Expert? Answer questions, earn points and help others
