Electrical Supplies Logo
Posted on Dec 06, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Coleman Powermate 3000-Will not start.
Will not Start.
Anonymous
Level 2:
  • Expert 169 Answers
  • Posted on Dec 09, 2008
Anonymous
Expert
Level 2:
Answers
169
Questions
Helped
234090
Points
413
You may know this already but I'll go over how to troubleshoot a small gasoline engine :-)
To run properly these engines need 3 things a) the right fuel/air mixture into the cylinder, b) compression, and c) spark at the right time. As you check out the engine you prove to yourself that each of these things is there.
First, double check the fuel valve and the run/stop switch. I've forgotten this once or twice and wasted time fixing what wasn't broken.
Next pull the starter rope. Do you feel a fair amount of resistance that gets stronger then weaker as the engine turns over? This is also when I listen for any odd noises.
Double check the fuel level in the tank and the amount of oil in the crankcase. Again, we're systematically proving that the darn thing ought to work.
OK, got fuel in the tank, oil in the crankcase, all controls to "go", and it feels like we have compression - that leaves checking it for spark. Take out the spark plug and look at the end of it. If it isn't nice and clean go get a new one. Lay the spark plug against the cylinder head so that you can see the gap at the business end and gently pull the starter rope, you should see a nice bluish spark jump across the gap. You may need a friend to help by pulling the rope while you watch the gap ;-)
This doesn't check that the plug will spark when it's under compression in the cylinder but it proves that the electrical parts of the engine are working.
If there was any sort of spark at all reinstall the plug (use the new one if you found it dirty). Take the air cleaner off of the engine an inspect it, if it's dusty tap it against your hand to knock the dust out of it, if it's oily and/or wet get a new one. Get yourself a can of carb cleaner, brake cleaner, or other handy starting aid and shoot a 1 second blast of it thru the carb intake. You want to get the brake/carb cleaner past the carb and into the intake manifold. Do Not use ether or gasoline for this at penalty of your eyebrows. Close the choke half way and pull the rope, if the engine starts or tries to start and then stops you probably have carb problems, if there is no detonation at all from the cylinder you may have compression or spark problems.
Carb problems:
Put a catch pan under the carb, I use a cut down 1 gallon oil container. Using a 13mm wrench loosen the bolt on the bottom of the carb bowl and then remove it by hand. You should see fuel start to come out of the hole where the main jet you just took off was. If you don't see fuel come out gently remove the bowl from the carb, be careful of the oring/gasket between the bowl and the carb body. At this point fuel should be pouring out into the catch basin, if it isn't you have to find out what's blocking the fuel supply. Shut off the fuel valve, many fuel valves have a built in filter in the body of the valve. If you've got one of these you can take the bottom of the valve apart with a 10mm wrench and clean/inspect the screen inside, be carefull of the oring here too.. If the filter is OK, remove the float and needle vale from the carb by pulling out the hinge pin in the float, when you turn the fuel valve back on fuel should pour out into the catch pan, if not you need to remove, check, and possibly replace the fuel line.
If you've got fuel to the carb (fuel poured into the catch pan above), you need to remove, clean, service (lube, inspect) and reinstall the carb. There aren't many adjustments on modern small engine carbs.
Spark/Compression problems:
Get a spark tester and check that the engine gets spark with the plug installed. If it does not, you have to determine why starting at the run/stop switch. Find the (usually black) wire at the center of the switch and disconnect it. Check for spark again, if you got spark you may have a bad switch. If you didn't get spark you probably have a bad ignition module which is located under the blower housing and above the flywheel.
The only good way to check compression is to use a compression tester. You should see 50 psi or more of compression for the engine to work. If you don't have good compression, especially if you get very low compression check the valves first then the head gasket.
If everything checks, you have fuel, compression, and spark but the engine still won't run. You may have a broken flywheel key. To check that you have to remove the blower housing, the ignition module, and then the flywheel.
Hope this helps narrow down the problem, feel free to ask me directly if you need more help.
Carl
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 12, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1529
Points
I had a new 3000 placed in remote spot after a year we needed it and would not start We found a wire coupler that had never been hooked up I think in control pannel
3 Related Answers
Anonymous
  • Posted on Nov 19, 2008
SOURCE: looking for manual for generator...won't start
I had the exact same problem. There a few things you need to do first.
1) Make sure the fuel line knob is turned to the Open position; this knob is located under the gas tank.
2) Turn the power switch to on : it is a little red switch located near the pull-handle on the front of the generator. It needs to be on 'I' not on 'O'
3) Turn the choke lever on: it is a little steel lever with an arrow at the tip. Move the lever in the direction the arrow is pointing.
4) Make sure you have gas left in the tank: it may have evaporated or gummed up if you did mix in a fuel stabilizer before putting it away for storage.
If none of these things work , then you carburator may be full of water and gas lines gummed up.
These Gens need to be started up at least once a month to make sure they keep working properly.
Fred
Anonymous
  • Posted on Jun 12, 2009
SOURCE: pull start recoil assembly
I bought a replacement recoil starter for my 1850 at Pats small engine parts. The part number for a 3.5 B & S is 499706. If you look on the heat shield on the side of the motor there is the engine model and s/n. Hope this helps.
protek480
Craig Butler
  • 1730 Answers
  • Posted on Aug 01, 2009
SOURCE: My coleman powermate generator will start but will not generate.
The voltage regulator controls the output. You will need to check that first.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
3answers
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
8helpful
2answers
Coleman Powermate 5000 with 10 HP Tecumseh engine. It had a float problem and leaked gas out the air filter. I replaced the float and stopped the leak, but now it won't start. It will start if engine...
I have a Coleman Powermate 5000 with 10 HP Tecumseh engine. It is very hard to get started. once started runs great . But when you shut it off and try to restart it it will not start.
I have plenty of fire. I also replace the carb.
I still have problems getting it started. I tried to start it with out the filter also. What can i try next?
Thanks for any help
2helpful
2answers
Have a coleman powermate 5000. Won't start. Laid
this model has one fuel shut ff switch it's on the tank.if it's turned on then fuel is reaching the carb.
you should check oil level, and check if there is any spark in it.
1helpful
2answers
Ust 3000 generator-only idles-no voltage output
chek brushes...if they seemed ok then replace AVR card
Will not start
Hi
Keep it simple, have you pushed the reset button?
Ther may also be a master push / pull switch on the switch housing.
1helpful
Starting the Coleman Powermate 5000 generator .....
Thanks for the offer of the Premium Assistance Plan, but no thanks -- I was able to get the answer from a local department store from their "lawn & garden" center....
J
Coleman powermate 3750 watt brand new I started it
Check the oil level & try again to start many times until it became loose because the engine became stock up for long time not use.
I have a coleman powermate 6200 that puts out no elecietety
Here is a link to a general solution I posted some time ago.
If that doesn't solve the problem let me know.
Regards,
Carl
Top Coleman Electrical Supplies Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
john h
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
