Honda 3000 Watt  Portable Generator Logo
Dave Wallingford Posted on Jun 30, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Honda e2000i generator no spark
Tipped over wont start no spark
KHITTA
Level 2:
New Friend:
  • Expert 61 Answers
  • Posted on Aug 14, 2012
KHITTA
Expert
Level 2:
New Friend:
Answers
61
Questions
Helped
23413
Points
146
If there is no spark in the plug as you are saying for that matter check the current coil and the inverter section for the loss of current if you have already changed the sparkplug if not do change
Honda EB3000c generator won't start?
Three of the most common causes for this would be:
- A worn spark plug (solution: replace spark plug)
- A clogged fuel filter (solution: clean or replace filter)
- Oil level too low/high (solution: check level, add or remove oil)
There are many videos available online that should help you fix this yourself. If none of these help, you should take the generator to your local dealer/shop.
Took my ev6010 generator out and put it back in but hooked up the starter motor to the ground not to the positive and now it wont start. I also changed the oil and coolant.
On the ev6010 Honda generator the posive starter wire is black and was accidently hooked up to the chassis ground wire. Then the start button was pushed and nothing happened. I corrected the wire hookup to the positive side but will not start still
2answers
My honda 5.5 gx160 generator wont start
Is the ignition switch turned to "ON" . Is it full of oil?
1helpful
1994 honda cbr 600 motorcycle wont start just turns over put new petrol and replaced plugs but still wont start please help
check pulse generator circuit for any opens or shorts..even if you still show a weak purplish/red spark its bad..it must be a big bluish/white spark..check plug #1 for spark and then check #3 foe spark if there both week then its your pulse generators that are bad ..but if one of them has a blushish spark then it that systems coil..eg #1and#4 or the #2and #3 coils..
1helpful
Honda EG 2200 Generator wont Start
First make sure that you have a spark; remove the spark plug and position it so that the threads are touching the engine frame. Pull the cord and check the plug for spark. If you have spark, put the plug back in.
Get some starting fluid and spray it into the air intake of the carbuerator. Try to start the engine. If it starts and then stops, that indicates that you have a fuel delivery problem. Clean the fuel filter.
Top Honda Electrical Supplies Experts
vince
Paul Carew
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
