Question about Rotel Audio Players & Recorders
Surround left cracks in the ROTEL RSX 1055 - Rotel Audio Players & Recorders
3 Suggested Answers
SOURCE:
chliu528
SOURCE: My Rotel RSX-972 surround sound receiver has no
I had the same problem with my Rotel RSX-972. The problem is the capacitor that keeps the setting memory charged has gone bad. So after power off memory is lost, including input setting for each channel. That's why there's no sound.
You'll have to hook up the receiver monitor to the TV and set them again via the On Screen Display(OSD). Work around is keep it powered up and use remote to put receiver in stand-by. Permanent fix is to contact Rotel on replacing the capacitor.
Posted on Nov 08, 2016
  • 51971 Answers
SOURCE: I recently bought a Rotel RSX 1067 surround receiver. I am tying to play through the front speakers 2 CH function but the sound is weak
The speaker impedance may not match that of the receiver.
Posted on Dec 21, 2016
Rotel rsx 1065 switches on. every single thing is lit up in the display panel on receiver. But unable to select anything and of course no sound. what could be wrong?
Probably the EEPROM, the heart and brain of the appliance.
I had the same issue with my AIWA, could not figure out the cause, took it in, tech told me EEPROM is blown.
Not economical to repair.
Nov 20, 2017 | Rotel Audio Players & Recorders
Rotel rcc-1055 won't stop spinning carousel. It will sometimes play a disc but mostly spinning looking for a disc
Your changer has lost its mind and is doing crazy things.just like mine. Software issue not repairable.. Go shopping.
Sep 12, 2017 | Rotel Audio Players & Recorders
My Rotel RSP-976 analog inputs don't produce sound. I did all the OSD settings but to no avail
Hi Awal. Interesting problem. Have you tried another pair of leads? What source are you using please, cd tuner etc? I noticed the the names for the five audio/video inputs can be customized by the user, Maybe there is a firmware issue? With the unit being surround sound Have you tried running in 2 chanels only?
Jan 06, 2015 | Rotel Audio Players & Recorders
Why my URC SL-9000 can not control ROTEL RSX-1056 AV Reveiver
Do an auto search method to search for codes. If the remote control have set-up code to your device, you will win. If not, buy an other remote control, which have set-up code/s to your device brand.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 02, 2014 | URC-Universal-Remote-Controls Remote...
Where can we buy the remote of RSX 1067 7IN1
I do not know anything about your brand or market, but I have had good success with replacement remotes at http://www.replacementremotes.com/
They have a very wide selection of mostly refurbished remotes.
Originally supplied with RSX 1058 is this:
http://www.replacementremotes.com/ROTEL/Buy-RR-1061-RR1061-Audio-Remote-Control.html
Jan 18, 2014 | Rotel Audio Players & Recorders
Hello I have a rotel RSX 1056 witch I used once six years ago for two months . I lhavent used it since then , and now I decided to hook it back up and I have no audio . It turns on but when I set a radio...
If you stored it in an area with high moisture content it is probably corroded at most of the contact switches. Capacitors also hate moisture, especially paper capacitors! The tuner is also probably oxidized inside. Now is the time to be brave and pull it apart, but first PULL OUT THE PLUG from the wall. Have at it with electric parts cleaner spray and clean, dry compressed air. If you believe that just because you stored it in your house, there was no moisture, think again! Radios like cars do not do well in storage unless you take precautions to protect them!
Jan 02, 2013 | Rotel Rsx-1056 Receiver
Rotel RHB-10 amp channel not working
YOU ARE NOT RIGHT IT SHOULD GIVE AT LAEST A LOW VOLUME SOUND WITH A LOT OF DISTORSION AND A CRACKING NOISE IF DOES I GUESS THAT YOU HAD THIS AMP IN A PLACE WITH A LOT OF HUMIDITY AND YOU HAVEN'T WORK IT FOR SOME TIME IF I AM RIGHT PUT YOUR AMP IN THE SUN AND WORK IT FOR 10 MIN WITH A 5 MIN BREAK LET ME KNOW THE RESULTS
Nov 14, 2012 | Rotel Audio Players & Recorders
Hi i have a Rotel Rsx 1067, powers up then off, the remote control is using new batteries, the receiver pickups the remote sensor but doesn't do nothing. volume control does not adjust up or down, and when...
Try fixing your remote controller, because sometimes when we neglected to replace our remote batteries for a while, it will leak and it will build up on the contacts of the remote pad.
Take off the battery, open the back of your remote, lift the circuit board, clean the green painted part with cotton balls slightly damp with rubbing alcohol as well as the black thingy behind your remote pad, let it dry put it back together, replace with a new battery and try if it works.
Good luck
Sep 28, 2010 | Rotel RX-965 Receiver
My Rotel RSX-972 surround sound receiver has no power, the repair centre cannot isolate the problem and they do not have a service manual to guide them,a service manual would be handy??
Unless yuo can find a Rotel authorized service center, you are not likely to find any service information. These units should not be difficult to repair. Their designs are pretty much standard with a few twists. Any shop that handles audio repair should be able to resolve this. If not, please post your location and I'll try to locate a shop for you.
Also, are there any indications that the unit is trying to work at all or is it completely dead?
Thanks,
Dan
Mar 25, 2009 | Rotel RX-965 Receiver
79 people viewed this question
Top Rotel Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
Are you a Rotel Audio Player and Recorder Expert? Answer questions, earn points and help others
