Kicker IK150 Digital Docking System w Alarm Docking Station for iPhoneiPod  White (IK150WH) Logo
Ally Smith Posted on Jun 30, 2012
My kicker iPod docking station displays aux-in and won't play the iPod there is nothing plugged into the aux jack point
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 12, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1194
Points
Turn rotary control counter clockwise to disable auxiliary input. When auxiliary input is disabled , menu will display "--".
  • Anonymous Nov 12, 2012
How do I connect my Lenco IPOD/IPhone Tower 1 docking station to my LG LeD tv to play tv audio through the tower speaker insteat of the tv speaker?
If your TV has RCA (L/R) audio outputs, buy a 3.5 mm Male to 2-Male RCA Adapter cable to hook up your TV to the 3.5 mm AUX IN jack on your docking station.
How do i tune my radio in on my Bush docking station ?
Probably the docking station has either a single push button labeled 'Source/Input' that you press on to change the audio source from 'iPod' to 'Radio/FM' to 'AUX' (the latter only if there is a 'AUX IN' jack on the docking station) or 2 or 3 separate source/input push buttons labeled as above ('AUX' may or may not be there).
How do I get music on my docking station through my iphone?
I would check to make sure you don't have a cable or headphones plugged into the Audio In jack. If not then I would suspect that you have a newer Ipod touch or classic that is not supported by this dock. Something changed a couple of models ago with ipods and the last two generations haven't been compatible on older devices meant to play through the dock connector. I have the same problem with an older Sony car stereo.
If you do have a newer Ipod then you can either get the patch cable to go from your headphone jack to the Audio in jack on the dock or you will need to get a newer dock.
https://docs.sony.com/release/ICFC1IP.pdf
I have an lg home cinema and docking station GT462DZ . Sometimes, when i try to dock my ipod touch in it , it says 'check ipod' and it won't play music . It won't work. I always restart my...
It could be that some dust or something has got inside the dock and giving a bad connection. Check both devices for damage to the dock connections.
Don't how to connect iphone to ear speaker
moz-screenshot-12.pngmoz-screenshot-13.pngmoz-screenshot-14.pngmoz-screenshot-15.png honestytessy.jpgHow to Connect an iPod to a Speaker Bar
A speaker bar is a (usually portable) speaker system that includes a dock for an iPod. The unit is usually bar-shaped, with either a rectangular or cylindrical cross-section. Connecting an iPod to a speaker bar is usually as simple as plugging it in. Many speaker bars will also charge the iPod while it is connected. However some do not have an iPod dock, in which case the iPod must be connected by a 3.5mm audio cable.
Instructions
Things You'll Need:
* 3.5mm cable (for some speaker bars)
Turn the iPod on. Look to see if the speaker bar has a dock for the iPod. The dock will fit an iPod perfectly and will generally be located in the center of the speaker bar. There will be a connector that resembles the connector on the docking cable that came with the iPod. Place the iPod on the docking station and turn on the speaker bar. Such is the case with the "2.1 Channel Bar Speaker with Dock for iPod" or the "Yamaha YAS-71BL Front Surround Speaker System"
iPod headphones use a 3.5mm audio cable.
Connect the iPod via the 3.5mm cable. If the speaker bar does not have a docking station it will have a 3.5mm cable connector with a jack like the headphone jack on iPod ear pods. Plug the 3.5mm cable in the iPod headphone jack. Plug the other end in the iPod. Turn on the speaker bar. The procedure is straight forward and Apple specifically designed the headphone jack with third party stereos in mind.
Select a song on the iPod and play it. The speaker bar will play the music from the iPod.
Hope that helped..
have a nice day.
Is there a way to hook up an ipod to this stereo so it will play the ipod music through the stereo? Can I purchase a docking station that will hook up to this stereo?
Just get an adapter for to connect from the Ipod headphone jack to a standard RCA cable pair. Jack into AUX or whatever available input you have.
3helpful
No sound when I put Zune in the docking station.
I just spoke to Stillwater Designs tech support. I had the same problem - Zune in dock, Zune working, no sound. I also tried to play it thru the AV jack -- same problem. After asking me if I had unplugged the Kicker (I had, several times), they authorized a return. Not sure whether I want to return to Amazon for credit or return to Stillwater Designs for new unit.
Will NAD 712 accept an iPod Docking Station?
A 712 is not set up to use an Ipod USB dock.  You can buy a dock that will use RCA jacks into an old stereo - Apple sells them, others too.  Then the Ipod sits up and you can look at it.  Or you can buy the 1/8" stereo plug to two RCA plugs that Radio Shack has been selling for 30-40 years, plug one end into your Ipod headphone jack, and run the two RCA plugs into your Aux input.  That costs about $5, and is easy as pie.  An Ipod will play through any old receiver, but the USB docks will not plug into them.
Dec 10, 2008 • NAD 712
2helpful
2answers
Ipod nano not charging on docking system, it has low battery if none, can play with a little charge on ipod but has to be charged with plug first, the docking system is brand new aswell and is charging...
for some **** reason the new ipod nano (4th generation) does not support FireWire and therefore will not charge on any docking station that is a FireWire power sorce - which seems to be most of them out there!
have same problem so will end up charging from computer as docking station still plays the new nano, no point in buying new docking station just for sake of charging!
Top Kicker Audio Players & Recorders Experts
 Mikey
Mikey
diyfixtool phonefix
diyfixtool phonefix
Adviser101
Are you a Kicker Audio Player and Recorder Expert? Answer questions, earn points and help others
