Kyocera TASKalfa 180 Copier Logo
A
Anonymous Posted on Jun 30, 2012
My kyocera taskalfa 180 asking me to call service C6000. How can fix this error?
  • claudia hernandez
    claudia hernandez Aug 19, 2016
    gracias 10000,me resirvio,muy util...gracias!!!
  • Rajib Barman Varma
    Rajib Barman Varma Apr 27, 2017
    at first u see the fusing unit install are correctly and then u press 10871087 u look the display in 000 u press 163 and start then dow arrow of EXECUTE then off and off machine ready ok
manimukta_ma
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 30, 2014
manimukta_ma
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5041
Points
24
My kyocera taskalfa 180 shows an error.call service c6000.what should i do
Ks Omanakkuttan
Level 1:
  • Contributor 2 Answers
  • Posted on Oct 15, 2013
Ks Omanakkuttan
Contributor
Level 1:
Answers
Questions
0
Helped
7553
Points
8
Thanks for ever............ thank you sir
Biplab Debnath
Level 1:
New Friend:
  • Posted on Apr 06, 2016
Biplab Debnath
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5041
Points
21
Zakaria Pasau
Level 1:
New Friend:
  • Posted on Jul 08, 2014
Zakaria Pasau
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5041
Points
5
Thank's.... nice solution..!!!
Rajib Barman Varma
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Dec 09, 2016
Rajib Barman Varma
Contributor
Level 1:
New Friend:
Answers
23
Questions
8
Helped
22011
Points
77
Either at first you go service mode 10871087 and press 163 START neither you change fuser unit
4 Related Answers
Anonymous
  • 74 Answers
  • Posted on Mar 27, 2010
SOURCE: Morning,
1650 machine is a medium size machine for small offices and home users. The machine is equipped with a self diagnostic function so it displays an error code whenever its processor detects a problem during copy process.
Some codes can be reset by simply opening and closing the front door or by turning the machin on and off, but there are some others that can be reset only by a service representative. C 6000 code is one of them. There are several causes that lead to this problem, i;e:
1. Unstable power source
2. Low volatage
3. Broken thermisted wire
4. Poor contact in the thermister connector terminals.
5. Heater lamps are broken or not installed correctly.
Here is the process to reset c 6000.
Enter 1087-1087 (1087 twice) from the keypad.
U000 will be displayed.
Enter 163 by using the keypad keys.
Press "Start" (the green button) twice.
The code will be reset and machine will start automatically.
If this code is appeared again, you may need to check the fusing section of the machine and it shoud be done only by a service engineer.
hamzaskilltd
amir hamza
  • 318 Answers
  • Posted on Jun 05, 2010
SOURCE: what to do, my kyocera displays call service C6000
heat roller low temperature
Anonymous
  • Posted on Nov 09, 2010
SOURCE: i also need a service
call service c3100
Henry Gertcher
  • 48 Answers
  • Posted on May 26, 2009
SOURCE: Kyocera Mita 1500 Error code 6000
This C6000 error code is triggered by a few things all having to do with the fixing heater wire. Ask your technician to check the thermistor, the thermal cutout and the connection between the thermistor and the power supply board. My guess would be that the power surge overloaded the power supply board. This is not something that can be reset and may require new parts.
The manuals that describe the error codes are only available to Kyocera technicians, sorry.
Henry
It is fuser error try resetting it by running mode 163, otherwise replace the fuser unit.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
1helpful
How to solve C6000 problem in Taskalfa 180/220?
Code C6000 Description Fuser heater break
The temperature does not reach 70 °C/ 158°F in 15 s before secondary stabilization.
Temperature rise of 1°C/1.8°F does not occur in 5 s before secondary stabilization (except during printing). Causes Poor contact in the fuser thermistor connector terminals.
Fuser thermistor installed incorrectly.
Fuser thermostat triggered.
Fuser heater installed incorrectly.
Broken fuser heater wire. Error Codes Kyocera Mita TASKalfa 180 Code C6000
1087 1087 then 163 reset it may prompt to turn off and on again,
if that does not reset copier replace the fuser assy
1helpful
2answers
Problem in printing, when you run TCT me c6000
c6000 is a fuser error code try replacing the fuser
C6000
http://fix-your-printer.blogspot.com/2012/05/solving-error-c6000-on-kyocera-mita.html see this
8helpful
3answers
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
