Pls..help me to continue playing it problems: it can't turn on(always) it doesn't read the disc properly(sometimes) the red reset button doesn't change to color green(always) ...................................................................................................................................................................................................... ''PLS.HELP ME'' that's all
SOURCE: My Ps2 light turns green then turns red
check to make sure your power cable is securely in, and check for any damage in the cable
SOURCE: PS2 slim Power Problem - Light is red goes green but nothing else.
Possible broken post that disengages the disc brake.
The disc will NOT spin if the post is broken. the post is(was) in the lid towards the back
SOURCE: Sony PS2 SCPH-30003 No data error. PLS Help
Adjusting the white gear is usually a temp fix. If your lucky and you move it one click at a time, It'll offset to a point where it will read the discs again.
Whats happening is the drive shaft is warping. This is a very common problem in all of the ps2 units.
You have 2 options.
They sell replacement ps2 cd roms if you look around with google.
Option 2 would be purchase a new ps2. Its roughly going to cost you $80.00 US to get a replacement cd rom for the ps2. Price different for a new one would be 30 bucks or so.
Personally i'd just snag a new system. The newer one's have fixed the cd rom problem so it won't happen.
Hope this helps ya.
SOURCE: PS2 SLIM NEW .NO VIDEO OUTPUT
try changing the av channel or if you are using a scart lead try taking out the three leads red yellow and white and put them in the front or side of the tv if you have this access.
SOURCE: ps3 wont read blue ray discs but will read dvd
sounds like the blue ray lens fried, u should be able to find one on ebay or craigs list not hard to put in
