I checked the spark plug gap and set it to 0.25 and turned the engine over and checked the points and no fire going to the coil to the points and i think that the voltage regulator might be bad realy don't know what else it could be
SOURCE: 1976 JD 214 lawn mower Kohler engine K321AQS
When it shuts down crack the fuel cap and listen for the woosh of a vacuum on the fuel tank. If you hear this, clean the pinhole vent in the fuel cap, or replace it. Being partially plugged would cause you to be starved for fuel and could explain your issue, and why it goes away after a period of time.
Regards, --W/D--
SOURCE: no spark at spark plug center of Coil
2000 ford escort ZX2. 4cyl . No spark at the spark plug. Wires are good.
SOURCE: Ford 9N problems; Changed plugs, wires,
You might check ground. some of these units were ground positive. did you switch the posts?This would cause problems since the electrons are on the inside of the condinser.
Good luck
Joe
SOURCE: My engine turns over fine, but I have no spark. I
Confused about having the magneto tested. First make sure the "air gap" is between .010 and .012. A good test is to leave the coil mounted but disconnect the single black wire that connects to the spade terminal on the coil. Turn the engine over and check for spark, if you have spark then reconnect the wire and test again. If you have no spark then the problem is within the grounding circuit and you would need to troubleshoot that area. Hope this gets you in the right direction.
