Nikon Coolpix Aw100 26292 Blue Hd Gps Waterproof Digital Camera 2gb Kit Logo
Anonymous Posted on Jun 29, 2012
My nikon coolpix AW100 has a black screen when it turns on
It has only been used 3 times in the water and has now started doing this video function works fine and the screen turns on for that but on camera mode or playback just plain black !! What do I need to do???!!!!????!!!?!?!?!?
  • 2 more comments
  • Anonymous Aug 05, 2012
    dear friend, i have the same problem with you but i can't find any solution. How did you fix it?? Please help
  • Anonymous Mar 29, 2014
    Nikon cool pic aw100
  • Maria Gabriel
    Maria Gabriel Jul 29, 2014
    I also had the same problem! If you found a solution, please help me!
  • Jurgen Dino
    Jurgen Dino Mar 04, 2023
    Im the have the same problem!
Paul
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on May 31, 2016
Paul
Contributor
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
14023
Points
10
I have found a simple permanent solution to this problem. The problem seems to be to do with the camera detecting when the mini usb plug is inserted. When you put the plug in the screen comes back to life. Therefore insert a small piece of twisted wire into the socket such as a paper clip cut to a small length so you can leave it there and close the lid. I was ready to throw this camera away but this fixed it.
Joel Dworkin
Level 1:
New Friend:
  • Posted on Aug 20, 2014
Joel Dworkin
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
14023
Points
My LCD was black but everything else worked fine. I snacked it against the palm of my hand as recommended and it worked immediately. Wish I had know when I was travelling.
Alejandro
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Sep 02, 2014
Alejandro
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
14564
Points
NIKOLAS
Level 1:
New Friend:
  • Posted on Sep 12, 2013
NIKOLAS
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
14023
Points
I HAVE ALSO THIS BLACK SCREEN PROBLEM I USED A HAIRDRYER 4 TIMES 3 MINUTES EACH TIME, AND THE PROBLEM IS FIXED FOR NOW HOPEFULLY I WILL NOT HAVE IT AGAIN
  • NIKOLAS Sep 12, 2013
Anonymous
Level 1:
New Friend:
  • Posted on Dec 08, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
14023
Points
I have this Nikon AW100 camera for over a year now, and since recently I also have this problem. I really love this camera but now only the video function works and for all the rest the screen doesn`t go on. It does take photos but the screen is off, nothing worked to fix the camera for me.
I hit the camera a few times, just like you people said here, with the front of the camera on my leg, palm of the hand, etc and nothing happened. (and I hit it really hard as it can survive a drop off 2 meters)
Then I hooked the camera up with a usb cable to a pc and unhooked it again and for a moment the `Coolpix`logo came up and in photo-modus the screen turned on but 3 seconds later turned off again.
Too bad, so now I`m returning this camera to the shop and send It to Nikon and I hope this is guarantee! Jimi, Belgium
5 Related Answers
Anonymous
  • 13 Answers
  • Posted on Nov 11, 2007
SOURCE: nikon coolpix s1 dig camera ,no picture
With the power off, hold the camera in your palm and smack the front of the camera on your leg or arm. You might have to smack it a few time to get it to work. It has to do with the camera CDD lense (shuttle) being stuck. By smacking it around, it will free up the lense. Being extra gentle with it though. It worked for me. Hope this help.
Anonymous
  • Posted on Feb 12, 2009
SOURCE: nikon coolpix S6 screen black
All you have to do is lay your camera with the LCD side down, make sure its on a soft surface like a carpet or a pillow. Once you have it laying down, put a peice or two of newspaper, or any paper, on top of the camera. and then hit it a few times with something. like a brush or anything hard like that. it worked for me. :) good luck.
Anonymous
  • Posted on Jan 06, 2009
SOURCE: nikon coolpix S3- most of the screen is black on shooting mode
I had the same problem with mine. I searched the web and came across this one. My camera had a black screen but everything else worked. I read some of the comments and a few people said to hit it. I hit the camera in the side of my hand a few times and it started to work. Thanks for the info. It sound carzy but it works.
Now working Nikon coolpix
Anonymous
  • Posted on Mar 21, 2008
SOURCE: Nikon CoolPix Flash Problem
This happened to me too!
Turn the dial to setup, push the menu button & select reset all. This will restore the defaults & let you use the flash again.
Anonymous
  • Posted on Aug 22, 2007
SOURCE: Nikon S6- LCD screen black
I have The same problem with my S6, and was wondering if you found a solution? Ive done everything but contact Nikon or a camera shop.
Camera is dead , battery is fine , nothing turns on
Nikon Coolpix S8200 Troubleshooting - iFixit
https://www.ifixit.com/Wiki/Nikon_Coolpix_s8200_Troubleshooting
iFixitThe Nikon Coolpix S8200 model was released in August of 2011 with a ... Flash won't work, but light bulb is fine; Flash is enabled but still won't go off. Camera won't turn on¶. You have tried turning on your camera and nothing is happening. ... Once a green light turns on, it is telling you that your battery is fully charged.
Coolpix S4000 won't turn on? - ePHOTOzine
https://www.ephotozine.com/.../coolpix-s4000-won-t-turn-on--97474
Jun 4, 2012 - Still won't power up mine so I am giving Nikon a call in the morning to see if they can figure out .... started up with both batteries all fine & dandy
Problem with Nikon Coolpix P510: Nikon Coolpix Talk F
Black screen but no display on ther camera
I've managed to fix it, fix it was quite easy .... simply connect the data cable to your PC then format the memory (backup memory contents), turn it on again. repair work
What to do is battery compartment gets wet?
I would put the camera in a bag of rice for several days to dry it before putting the batteries into the compartment.
I have nikon coolpix s210. when i turn on the camera, the view finder screen is black, i cannot take pictures as they come out black. though the flash and other functions work well. i can also see photos...
This problem (the screen with no picture) can be caused by a number of problems). One is that a connection with in the camera has disconnected. Another is the possibility of the LCD being bad or broken (some of these LCDs are hard to detect broken screens). Another problem could be with in the circuits has stopped working. Another could be that there is a problem with the CCD sensor. If any menus can be shown, then the problem is within the lens or sensor or something related. If you can see nothing on the screen, no matter what you pick, then the problems are harder to detect as to what is wrong.
2helpful
Black Screen
Did you leave it in the sun . Or in a hot place ? Was it wet in any way ?
1helpful
Nikon coolpix S51
Bad CCD, this is like film in a film camera. If the CCD becomes faulty it can no longer record images. This as a rule unless you can repair yourself is a repair not worth doing.
Camera Screen black
Time for a new camera, the cost to have it exchanged by Nikon is near the cost to replace.
4answers
Nikon s6 coolpix
I would check with Nikon and see if it's covered under warranty still. There could be something going on with the CCD unit
1helpful
Nikon coolpix S3- most of the screen is black on shooting mode
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
