There is a horizontal line across my Lenovo laptop. What is the remedy.
SOURCE: info on lenovo 0768 laptop screen is vertical instead of horizont
try ALT>+<CTRL>+<ARROW> three button at a time. the arrow you press, screen should go on that way. It works on most of the pc s. Should work on you too.
Please Rate me if it works.
Thanks
SOURCE: Lenovo 3000 N100 Screen Problem
First, plug a external monitor and toggle the screen to discard configuration or software problems. If the image displays correctly you have a problem either in the LCD screen or its connection cable.
Open the bezel and check for loose or damaged connection cable. Look specially next to the hinge, ON THE LEFT.
In case the problem is not the cable you might have to get a new LCD. You can have replacement parts and instructions here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ViewObjectID=56222
SOURCE: how to install xp in lenovo g550, its cant able
fist go bios & give boot from cd RAM save it exit from there insert XP CD it will ask you press any key ,just pess it then it will start coping fails & drivers after that XP will install ok
