Sony CDP-CE275 5-Disc CD Changer Logo
Posted on Dec 06, 2008
CDP 265 5-disc player
Tray revolves, but then opens. Looks like whatever is supposed to sense discs is not working. Can this be fixed or should I just buy a new player?
Anonymous
Level 1:
New Friend:
  • Contributor 35 Answers
  • Posted on Mar 02, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
35
Questions
0
Helped
107508
Points
90
If the disc is actually loading but won't read, try cleaning the laser lens with a cotton swab. Unplug the unit and remove the cover to access the laser. Spray a small amount of glass cleaner on the swab and gently wipe the lens of the laser assembly. Use the other end to dry it and remove excess dust. The only way you can tell if the disc is loading is to remove the top cover and observe if the disc at least loads and spins. If it does, try that procedure.
If the disc doesn't come up to the loaded position and spin (spin the disc by hand to confirm this), your gears may be out of alignment. Take the disc out, and use a screwdriver to manually turn the gear from the bottom of the unit. The gear should be visible through a small hole in the bottom toward the front of the unit. Take a slotted screwdriver and turn it until you see the laser assembly come up to the clamp that holds the disc in place. You may have to force it slightly if the gear has skipped a notch, it might "pop" as it goes past the tooth. Make sure you are turning it in the same direction as it moves when loading a disc! Once you do that, the laser should come up completely and be able to clamp the disc and read it.
1helpful
Is there an easy fix to the problem given in the details section below?
No there will not be a easy fix for this. You can keep putting up with this the way you have been or buy a new receiver and try to sell this one on craigslist, eBay, etc.
Disc will not load on sony cdp cx400
Loader mechanism fault. Not engages the CD properly to desired tray section. Contact any service technician. The loader tray should be repaired, and this is not a user repairable fault.
1helpful
I have a denon 3500 cd player my cd is stuck
Open the top cover of your CD using a screw driver, (usually a star screw driver),. Then, manually turn the driving gear of the CD tray to free the stucked tray and until to the point where you can take the disc from the tray. Be careful so the setting of the tray and the laser eye is not change. Then, close the close the cover and play. You can send your e-mail thru fix ya to let me know.
2answers
In/out dial on bottom of Sony CDP-C305 ... what does it do?
It is Transit Key to protect optical lens mechanism from shocks while transportation unit. remove it before playing unit.
CDP CX300 Disc player door remains open
Look on hifiengine.com for the service manual. I just got one for my Sony CDP-CX235 and there was definitely something about the door mechanism in it. The site is free to join too
Sony CD player C305 not playing
The laser or spin motor could be faulty.
Take it to a service centre for professional help.
John
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
