Suspension & Steering for Kia Amanti Sedan Logo
Posted on Jun 29, 2012
Replace rack and pinion on 04 kia amanti - Suspension & Steering for Kia Amanti Sedan
5 Related Answers
Anonymous
  • 410 Answers
  • Posted on May 19, 2009
SOURCE: what oil does 2005 kia amanti use
Depends on where you live in the country.  In TN where I live most people just use 10W30 all year, but if you live in a colder area you would use 10W30 in the summer and 5W30 in the winter.  Hope this helps.  Thanks for an honest rating.
Anonymous
  • 16 Answers
  • Posted on Jul 20, 2009
SOURCE: will be replacing brakes on 04 kia amanti soon.
Yes be careful with the caliper pistons, make sure they do not fall out.
You must push them back into the cylinders in order to put new pads in.
Thats now out of the way, Just be sure to lube up the sliding pins on the calipers. if you are replacing rotors be careful of the brake lines when you remove the caliper and to hang the caliper with a wire hanger or caliper hanger if you have one to not stress the brake lines
Anonymous
  • 4 Answers
  • Posted on Oct 16, 2009
SOURCE: Rack and pinion replacement, DIY or not?
Depends. Can't tell without seeing it. Try going to my favorite advisor who will help for free and tell you how much it will most likely cost you... Autozone. There is usually an experienced mechanic working there for just this reason. They may even recommend a good and reasonable repair shop locally who they personally trust. Follow their advice.
Anonymous
  • 1986 Answers
  • Posted on Nov 03, 2009
SOURCE: replacing my headlight bulb in my kia amanit 2004
  1. Open the hood of your KIA Amanti and look behind the headlight that has gone out. Locate the round knob on the back of the headlight.
  2. Turn the knob counterclockwise 1/4 of a turn and gently remove it from the back of the headlight. Carefully remove the electrical cable within the headlight housing that is attached to the back of the headlight bulb.
  3. Locate the metal clip that holds the light bulb in place by pushing the clip arm straight in and sliding it down. Remove the bulb from the headlight housing.
  4. Replace the old headlight bulb with new bulb. Secure it by sliding the metal clip up to hold the bulb in place. Reattach the electrical cable and replace the round knob to the back of the headlight housing.
  5. Turn on the headlights to verify that they are in working order.
Ronnie Smith
  • 77 Answers
  • Posted on Jan 30, 2010
SOURCE: 2004 kia sedona front end issues
This is a known problem and has been increasingly noted by sedona owners. Steering shaft becomes corroded making vehicle steer hard. They say due to salt but if you live anywhere it snows you cant avoid it.
Model/Build Years: KIA / SEDONA 2002-2005
Service Bulletin Number : TSB-019 NHTSA Item Number : 10027724 Summary Description : KIA: INCREASED STEERING EFFORT. IN AREAS WHERE HEAVY ROAD SALT USE OCCURS, INCREASED STEERING EFFORT AND NOISE (FROM STEERING INTERMEDIATE SHAFT) FOR SOME SEDONA. *PE
2answers
How to rebuild rack on 2002 kia Rio cinco
buy a rebuilt rack and pinion take them your old one as a core.
Bad rack and pinion on 2005 kia sadona
in order to replace your rack, you need to drop the engineand tranny craddle assembly. if you cant perform this procedure take it to a trained mechanic
How to remove rack and pinion from 99 chrysler lhs
There are few help links showing exact accurate procedure to replace Rack and Pinion. Click the link below and follow the procedure:-----
Pinion Seal Replace on Dodge Dakota? http://howtobyme.blogspot.in/2012/04/pinion-seal-replace-on-dodge-dakota.html
How to Replace a Rear Pinion Seal.
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-rear-pinion-seal.html
How to replace Power steering rack and pinion gear on Chevy Silverado 2500 HD? http://technoanswers.blogspot.in/2012/02/how-to-replace-power-steering-rack-and.html
How to replace Power Rack and Pinion Steering Gear on Acura Car Models? http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-power-rack-and-pinion.html
How to replace power rack and pinion steering gear on Toyota cruiser? http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-power-rack-and-pinion.html
Front Drive Pinion Seal Removal on Ford Explorer? http://repairhelpcenter.blogspot.in/2012/03/front-drive-pinion-seal-removal-on-ford.html
How to Replace Driveshaft, Pinion Flange & Seal?
http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-driveshaft-pinion-flange.html
How to Replace Power Rack & Pinion Steering Gear On 2007 Ford Taurus? http://repairhelpcenter.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
How to Remove Power Rack & Pinion Steering Gear on Ford Windstar? http://repairhelpcenter.blogspot.in/2012/03/how-to-remove-power-rack-pinion.html
Power Rack & Pinion Steering Gear replacing details for Buick Park Avenue and Pontiac Bonneville
http://repairhelpcenter.blogspot.in/2012/03/power-rack-pinion-steering-gear.html
How to Replace Power Rack & Pinion Steering Gear on Mercedes Benz Truck? http://howtobyme.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
How to replace Power Rack & Pinion Steering Gear on Toyota 4Runner? http://howtobyme.blogspot.in/2012/03/how-to-replace-power-rack-pinion_27.html
Power Rack & Pinion Steering Gear Replacing on Toyota Land Cruiser & Sequoia? http://schematicsdiagram.blogspot.in/2012/03/power-rack-pinion-steering-gear.html
Power Rack & Pinion Steering Gear Removal on Toyota RAV4? http://repairhelpcenter.blogspot.in/2012/03/power-rack-pinion-steering-gear-removal.html
How to Replace Power Rack & Pinion Steering Gear on Toyota Sienna? http://technoanswers.blogspot.in/2012/03/how-to-replace-power-rack-pinion.html
These details will help.
Thanks.
Steering is really stiff on my 04 f150. Fluid level is o.k. and the pump isn't makikng any n oise. Whats up?
have you had the rack and pinion looked at yet? the spool valve inside it might be going out, in that case the rack and pinion assembly will need to be replaced.
2answers
My cable battery bracket has just broken(sheared in 2 pieces)--how can I fix this so my car can start?
Put up the hood and hold the cable closed on the terminal with a pair of pliers. once the car starts it should run fine without the pliers as long as the charging system is working correctly. Then drive to a parts store and replace the cable.
1helpful
Steering becomes difficult sporadically
this could be one of 3 problems .1 are you low on fluid ,2 bad power steering pump.3 bad rack and pinion .
Replacing a rack and pinion
take it to a mechanic, this is not a job for a novice
Top Kia Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Kardoc
 Mikey
Mikey
Are you a Kia Vehicle Part and Accessory Expert? Answer questions, earn points and help others
