Posted on Jun 29, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why are my minolta EP3000 copies very dark all the time?
This just started recently. Thanks
Norman Weimar
Level 3:
  • Minolta Master 7,035 Answers
  • Posted on Feb 15, 2015
Norman Weimar
Minolta Master
Level 3:
Answers
7035
Questions
Helped
1910710
Points
11959
Has the optics been cleaned all the mirrors below the big glass how about the drum and developer has it been replaced?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2 Related Answers
Anonymous
  • 157 Answers
  • Posted on Sep 04, 2009
SOURCE: Dark horizontal lines appear across copies
This is usually caused by a dirty main charger grid, try cleaning it per the instructions in your operators guide. If you don't have the guide you may be able to download one from the Minolta Website at
http://kmbs.konicaminolta.us/content/support/supporthome.html
Anonymous
  • 11 Answers
  • Posted on Feb 25, 2010
SOURCE: Hi MR Tech. I have a minolta ep3000 copy machine
Toner ctg. failure to rotate - try re -inserting
2answers
In my Minolta EP3000, coming white lines while copying
clean the lens and also remove the drum cartridge and clean the drum error and developer section.
Dark copies are coming even I placed a plain white paper as the original in MINOLTA EP3000 Photocopier.
When was the last time the drum and developer where replaced and drum cartridge was clean along with transfer and sep assy??
On display showing problem code 500
Sir,
To clear this code requires you to gain access to the System reset. Open front door locate a small panel with one screw to release it in side will find two small black buttons find service and let machine reset if the code persists then your fusers is gone, the EP3000 is a legacy equipment may find a problem in locating spare parts if the thermistor, thermosat or fuser lamp is shot. Ensure machine is on when you attempt above.
2answers
My minolta EP3000 CSPRO shows error code coooo
Minolta ep3000 Cspro error code c0000 is plz sloved it
Minolta cs pro EP3000 copier. The copy is too dark even on lightest.thanks
Clean the optical parts:mirrors,lens and the charge and transfer/sepaRATOR CORONAS.
1helpful
Minolta ep3000 service m1 ? and how to reset ? can you help
M1= main motor
1. Does the transport motor (M1) operate during power up?
NO, Ensure the connection of the connector (PJ21A) is secure.
2. Replace the transport motor.
YES, Check if there is excessive load on any of the rollers,gears,etc.
3. Replace PWB-A.
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Daniel Blask
Daniel Blask
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
